harmonic balancer 66 352 - Ford Truck Enthusiasts Forums
Old 10-09-2012, 02:37 PM
wyowagner wyowagner is offline
wyowagner is starting off with a positive reputation.
i cant find a harmonic blancer anywhere for my 352 all there is is a repair sleeve what a repair sleep and how would i fix it?
Old 10-09-2012, 03:00 PM
P38fighter P38fighter is offline
P38fighter is gaining momentum as a positive member of FTE.
A repair sleeve will fix a groove worn into the balancer by the timing cover seal. It slips over the end of the snout and is held on by a tight fit and lock tite. It can be done successfully at home.
Why do you think you need a replacement harmonic balancer?
Old 10-09-2012, 05:13 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by wyowagner View Post
I can't find a harmonic balancer anywhere for my 352.
Where have you looked?
Reproduced, available from Dennis Carpenter. Listed/illustrated as C3AZ-6312-A in his 1957/66 repro truck parts catalog on page 40 @ $120.00. Call 800-476-9653, order this catalog...it's free.
Also available from Dearborn Classics in Bend OR (800-252-7427). Their part number: HAB10
If you don't want a repro, there are SIX available NOS from Green Sales Co. in Cincinnati OH (800-543-4959) / C3AZ-6312-E is the correct Ford part number.
Quote:
At the factory a rubber gasket is placed between the outer pulley and inner damper, then the three parts are pressed together forming a one piece assembly.
What happens to it: The rubber gasket age cracks/shrinks, the outer pulley begins to "walk away" from the inner damper.
If not noticed in time, the pulley will separate from the damper...fly off...taking assorted belts and etc along with it. May end up in the radiator core! Not pleasant.
Have you checked your trucks harmonic balancer recently? Probably not and I doubt too many other members of this forum have checked their harmonic balancers either.
need a oem style harmonic balancer for 352 fe rustyoleford66 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 2 06-23-2013 02:02 PM
352 swap to 390 FchasE 1961 - 1966 F-100 & Larger F-Series Trucks 16 02-27-2011 08:08 AM
67 352 harmonic balancer seanp1668 1967 - 1972 F-100 & Larger F-Series Trucks 3 01-01-2008 04:06 AM
67' 352 harmonic balancer seanp1668 Washington Chapter 2 12-31-2007 09:36 PM
Harmonic balancer interchange L-N-OR FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 3 10-13-2004 06:01 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
