computer codes for 1988 2.0 4 cyl - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 10-09-2012, 12:30 PM
nightowl10 nightowl10 is offline
nightowl10 is starting off with a positive reputation.
Question computer codes for 1988 2.0 4 cyl
Hi
I keep reading there are computer codes for various problems,
Would like to know if there is a computer in my 1988 ford ranger 2.0 liter engine, 4 cyl?
Thanks
Old 10-13-2012, 07:14 PM
pawpaw pawpaw is offline
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
I see you don't have any replies, so I'll see if I an get things started.
Yes your 1988 Ranger has an OBD-1 ECM computer. So you should have a dash mounted Check Engine Light (CEL) that if not burned out, should light up at KOEO for a self test, before you crank the engine. If the CEL isn't burned out, you can use a jumper wire in the under hood DLC to have the CEL blink any stored trouble codes.
A forum search will turn up links on how to extract any stored trouble codes, which can offer up good trouble shooting clues.
Exhaust port temp analysis / 1988 460 EFI EDsurvivor 1987 - 1996 F150 & Larger F-Series Trucks 8 09-11-2016 07:29 AM
help early 04 cylinders contribution test jimbo1969 6.0L Power Stroke Diesel 9 07-13-2016 11:50 PM
4.0 ohv help needed BigGreen'77 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 9 11-12-2014 07:13 PM
HELP f150 4.2 6cyl computer codes po171 & po303 Tyler Roberts 1997 - 2003 F150 1 09-22-2014 01:40 AM
Bad Computer? 854x4 Ranger & B-Series 27 09-16-2009 11:00 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
