Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > Georgia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Georgia Chapter Join Chapter, Leader: ChiefM SPONSORED BY:
  #1 (permalink)
Old 10-08-2012, 09:49 PM
Dtmaster2008's Avatar
Dtmaster2008 Dtmaster2008 is offline
1976 Ford F-100
Dtmaster2008 is starting off with a positive reputation.
possible engine swap
Hello all again, we are in the process of figuring out what went wrong right before I lost all power with the motor. In the process of just changing the exhaust manifold gasket and passenger side valve cover gasket, we found 3 to 4 bent valves. Seeing that I pulled the driver side cover and 3 more were bent and 2 had broke and went into the engine itself. Dont know whether or not the motor is good in worst case scenario ill be getting another motor. The truck supposed to be either a 360/390 with a c6 tranny, so if i did a swap what motors would match up to the c6. If i absolutely have to ill go down to a small block I just didnt want to pull the transmission but if push comes to shove, I will.
  #2 (permalink)
Old 11-05-2012, 07:07 PM
Alex from GA Alex from GA is offline
Garage is empty, add now
Alex from GA is starting off with a positive reputation.
The only engines that would fit your existing transmission is another FE; 352, 360, 390, 406, 410 or 428.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
