Georgia Chapter Join Chapter, Leader: ChiefM SPONSORED BY:
4bbl manifold for a 390
Old 10-09-2012, 02:42 PM
Dtmaster2008's Avatar
Dtmaster2008
Dtmaster2008 is offline
All is well with the engine, from the looks of it something just caused the timing to jump so now I dont have to worry about an engine swap anymore. I can get a Holley 4bbl but now my only thing is finding a manifold for the engine. Anybody have a 4bbl intake looking to get rid of, its a 390FE.
Old 10-09-2012, 08:11 PM
ChiefM's Avatar
ChiefM
ChiefM is offline
Glad to hear the engine is OK, What are you going to do about the bent valves?
Old 10-10-2012, 01:53 AM
Dtmaster2008
since the timing gears got, due to bad gas/water in the fuel, were gonna get a new set of them as well as another lifter as one of the went to bits. I've got a full set of push rods so basically after we replace the timing gears it's back together it goes and since we done took off the intake I might as well swap out to a 4bbl holley 650 as it's currently a 2bbl and power wise it couldn't pull greasy string out of a bulls ***.
Old 10-10-2012, 03:21 AM
smokenchoken's Avatar
smokenchoken
smokenchoken is offline
I might as well swap out to a 4bbl holley 650 as it's currently a 2bbl and power wise it couldn't pull greasy string out of a bulls ***. that's funny...... but seriously there might be something more serious if a 2bbl 390 doesn't have that much power (i have run 360's and 390's w/ 2bbl and they were plenty stout) and you said it jumped time i had a 352 jump time and all sorts of bad things happened how did your dizzy gear look when you pulled it out???
Old 10-10-2012, 05:45 AM
Dtmaster2008
We havent pulled the gears out yet, thats our goal for today. Hopefully nothing else will go wrong as from the looks the heads are in good shape and from what we looked at the cam everything seemed to be in good condition. Anything that came off the truck my dad would have looked at and would have been able to tell right off as he has a little experience with old dentsides as one he used to have was a 77 f100 with a 302.
Old 10-15-2012, 09:40 PM
DeepRoots's Avatar
DeepRoots
DeepRoots is offline
DtMaster, I've got a T intake if you are interested.
I've also got a F427 aluminum intake that requires a lil love to be usable.
Old 10-16-2012, 05:17 PM
Dtmaster2008
Ok thanks deeproots, unfortunately I did have to get another engine in the end there would have more money into the one I had so I got another 360 and now in the process looking over the new one and it also has a 2bbl so I will still be needing a 4bbl intake. Send me a pm on the 2 you have and pictures also if you can. I won't be needin it but in a week or two I will once we get it all setup.
Another question, in all of yall's opinion, would I be better off with a holley 650 or quadrajet 600? I got a holley but a guy I know wants it to drop it on his blazers's 350 he just dropped in it. Main reason I'm asking because he seems pretty insistent and he says the quad was setup for a ford but I thought the quadrajet was about the best you could get period for a carburator, just curious on that one.
Old 10-16-2012, 11:08 PM
DeepRoots's Avatar
DeepRoots
I'm at work.... I don't get home for another 2.5 weeks or so.
If you still need one at that time, I'll pm ya at that time.
Ohh and unless you have an open intake, or use a large open spacer a quadrajet wouldn't work. Stick with a holely for ease of hookup.
Old 11-05-2012, 07:38 PM
Alex from GA's Avatar
Alex from GA
Alex from GA is offline
IMO if you decide on a 4 bbl manifold get an aluminum one preferably a dual plane. Your back will thank you.
Old 11-07-2012, 08:19 AM
smokenchoken
go single plane dual plane is for rpms and these motors are not made for the rpms they are made for low end torque
Old 11-07-2012, 07:21 PM
Alex from GA
I believe if you'll do some research you'll see you have it backwards.
Old 11-07-2012, 09:20 PM
smokenchoken
apparently i am indeed wrong on how i wrote that good catch alex fingers outrunning the brain before morning coffee
Old 11-08-2012, 07:23 AM
DeepRoots's Avatar
DeepRoots
It doesn't matter anyway... Fe's have such a huge variety of intakes to pick from.
With single plane, there is a huge difference between a Victor, Dove TunnelWedge, and a Streetmaster.
either way, for a stock motor, they are all overkill.
mvcp
15
01-13-2019 08:18 PM
Mav06
11-17-2006 11:21 AM
dusty2052000
03-20-2006 09:23 PM
custom69
17
05-10-2005 11:43 PM
OneFine69
18
12-23-2002 11:30 PM
Quick Reply: 4bbl manifold for a 390
