Hood Lock
Old 10-08-2012, 09:08 PM
THartman's Avatar
THartman
THartman is offline
Hood Lock
What works best for locking the hood?
I know there are some unique approaches. Unfortunately the search didn't find them for me.
Old 10-09-2012, 08:48 AM
ibuzzard's Avatar
ibuzzard
ibuzzard is offline
Panties NOT in a Twist
The stock hood latch works fine,for over 50 years now.Just feeling the need to throw cash around? I'll put my catchers mitt on!LOL
Old 10-09-2012, 09:08 AM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
JC Whitney used to make one. IIRC it locked with the ignition switch.
Old 10-09-2012, 08:21 PM
THartman's Avatar
THartman
THartman is offline
Thanks, Vntgtrk. You are correct I am looking for a lock to supplement the stock latch. I found some on JCWhitney like this one Rugged Ridge JEEP HOOD LOCK - JCWhitney
Old 10-09-2012, 08:52 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
I may go with something similar myself. Maybe we should google Rugged Ridge?
Another viable option is the old, venerable piece of chain and a padlock. As far as vehicle theft protection I've used an electric fuel pump with a hidden on/off switch.
Old 10-09-2012, 08:57 PM
ibuzzard's Avatar
ibuzzard
ibuzzard is offline
Not to belabor a point - BUT - the hood on my 59 is so heavy , I cannot imagine it blowing open at the speeds most of us drive our old trucks.Now, if you've got an expensive motor or engine components, that's another story.
Old 10-10-2012, 05:38 AM
THartman's Avatar
THartman
THartman is offline
My concern is more of someone opening the hood and stealing, messing, manipulating things inside it.
Old 07-10-2013, 10:00 PM
Maltman's Avatar
Maltman
Maltman is offline
did you ever find a way to lock? I am looking into same thing
Old 07-10-2013, 10:16 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
http://www.ebay.com/itm/Mr-Gasket-Hood-Pins-Locking-Style-4-Long-7-16-Dia-Steel-Chrome-Plated-Kit-/330941968155?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d0dadaf1b&vxp=mtrThis is always an option. But to me, they look too high school. But they do work if you're willing to cut up a perfectly good hood
Old 07-11-2013, 12:45 AM
Maltman's Avatar
Maltman
Maltman is offline
I wouldn't cut the hood...
Old 07-11-2013, 09:19 AM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
Me neither. I'm working my brain to come up with a cable and a padlock arrangement. It'll wake me up in the middle of the night when the right idea strikes
Old 07-11-2013, 02:57 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
Here's what I fabbed up for my mustang....(I do have a pat. pending filed) but I have no issue with someone building one for themselves.
Inside the box is a bar that slide with the use of a cable that blocks the locking forks from moving...in essence...the hood is locked.
Old 07-11-2013, 04:19 PM
Col Flashman's Avatar
Col Flashman
Col Flashman is offline
I went Olde Schoole & put a Chain & Padlock in place.
Old 07-11-2013, 05:12 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
That's prolly the way I'm gonna go. But I'll use a tailgate cable I have. I'm not sure what it came from, but I'm like many here. I have Pack Rat Syndrome, a.k.a. PRS. How many of us here who build trucks are also afflicted? Don't be afraid to admit it. Acknowledging the problem is the first step to recovery.
Old 07-12-2013, 09:25 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
You think a 1957/60 hood is heavy? 1961/66 is heavier and people tend to slam it down, which over time, causes the hood lock plate to bend downwards.
Sooner or later, the hood flies up! Same scenario applies to 1957/60 and 1967/79's as well. You know how you can tell? Look at the rear of the hood where it meets the cowl panel.
If the hood is higher than the cowl, hood has flown up, which causes the 'weak sister' hinges to stretch. Lotsa luck aligning the hood with stretched hinges.
Hood flew up so often on "red pig" (so called cuz Ralph Willams Ford's beat to death 1957 F100 parts truck had a 'Col Flashman' Rustoleum paint job), that we installed a chain/padlock to keep it from doing so.
Quick Reply: Hood Lock
