View Poll Results: What Type Alternator and What Volts do you see it run At
Does it run at 12.0-12.9 volts at all times
0%
Multiple Choice Poll. Voters: 38. You may not vote on this poll
Poll Alternator Type and Operating Characteristics
Seems to be some confusion out there or maybe its Just Me being Curious about what out Alternators are Supposed to Operate Volts wise
So I thought we Give everyone a Chance to Chime In with what you Guys see Happening With Alternator Output On Your Trucks
Thanks For Playing the Ford 6.0L Alternator Lottery
After it goes up to 14 volt Does it Stay at 14.0 volt range the Duration of the trip???
And No the DC Alternator wont have any affect that first 30-45 seconds thats ALL the Batterys there till the Glow Plugs shut off upto 2 minutes
I just put new Batterys in and would hang in the same range the first 30-45 seconds run Rough
But with the New Batterys WOW What a HUGE Diffrence Huge and my old Batterys were not that bad yet
Me Too Duralast Golds 1000ca/850CCA
Did you notice a Big diffrence in How smooth the truck runs the first 0-120seconds??
I did it would have been Very Similar to Sticktion issue that first 2 minutes or while GP are on
After i start the truck it runs between 11.5 and 11.9, after a minute or so it starts getting a charge and it runs 13.6 to 13.9 and once in awhile it will pop up to 14 but it doesnt stay there. I am running the motorcraft 750 CCA batteries.
Last edited by mustang_309; 10-08-2012 at 09:58 PM. Reason: Forgot to add what type of batteries i was running
Before that it used to start like an angry old bear.
I think that is where most of the "confusion" comes from given voltage readings have traditionally been taken at the battery terminals for 100+ years and now with OBD readers the voltage readings are now skewed in that the OBD port has some amount of voltage drop.
13.6-13.8 volts at the port for me equals about 14.0-14.2 volts at the battery.
With my old 6G was 13.0-13.2 volts.
I have brand new AC Delco 850cca batteries BTW.
Josh
Josh
Josh
Josh
Josh
Josh
Thats Exactly it Josh LOL I didnt know you were adding voltage
All of us are Giving the Value we see at the OBDII Port
Your the Odd Man Out by Adding 0.10-0.40 Volts to your numbers for the voltage drop from the length of the Wire to the OBDII Port that is LOST
Hopefulley everyone else will just post what they read at the Gauge via OBDII Port
And keep in mind not everyone has an OBD reader/scanner to get those voltages. It has always been at the battery. That is the REAL voltage, not a reading after miles of wiring harness.
Josh
Im with ya
But if they only can test at the Batterys they dont see the whole picture the alternator output Voltage will change/drop after the trucks been driven long enough that the Batterys are toppped back off and have recovered from the drain when the truck was started
They would need to check it Multiple times each drive cycle IMO
