steering trouble. - Ford Truck Enthusiasts Forums
steering trouble.
Old 10-08-2012, 09:45 PM
dorideher's Avatar
dorideher dorideher is offline
dorideher is starting off with a positive reputation.
steering trouble.
I have a 63 f250 and the steering has got a little sloppy. It works fine making left turns, but when making right turns it feels like the steering wheel is slipping in the turns. When I straighten back out after a curve I can feel the wheels slowly moving back straight. I changed tie rod ends and kingpins seem good. I also hear some knocking in the front end when hitting bumps and pot holes. What should I check next. Could it be the shocks and if so how can I check them. Thanks.
Old 10-11-2012, 07:40 PM
dorideher's Avatar
Anyone with any advice? I did find today that the king pins have up and down play from not having enough spacers. (There should be no play at all. Right????) That is defiantly my knocking noise, but would that also cause loose steering?
Old 10-11-2012, 11:11 PM
jhooch's Avatar
jhooch jhooch is offline
jhooch is gaining momentum as a positive member of FTE.
You could have an internal problem with the steering gear itself. When you turn the steering wheel sitting in the truck do the wheels move or is there a delay before the front wheels react to what you are doing?
Old 10-12-2012, 06:10 AM
dorideher's Avatar
When sitting in the driveway, there is no play. The wheels move in sync with the steering wheel. Maybe I should just replace the kingpins and go from there. Thanks.
Old 10-12-2012, 07:43 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1963: Ford introduced "Lifetime Lubrication" plugged the Zerk (grease) fittings with rubber plugs. Remove the plugs, install the fittings...especially in the spindles.
Lifetime = Until the 2 year or 24,000 mile warranty ran out!
Steering issue Paul Anspach 1999 to 2016 Super Duty 8 01-25-2016 09:51 AM
Crunch-Pop-Thump Noise from Steering Gear Box? golfnut324 1994.5 - 1997 7.3L Power Stroke Diesel 5 01-13-2016 12:37 PM
Heavy steering thinksnow 6.0L Power Stroke Diesel 10 05-06-2015 07:20 PM
steering wheel jerky when coming back to center? Bite N Hold Excursion - King of SUVs 6 03-14-2015 06:09 PM
'88 Bronco II - Steering pulls after hard left? Josh S Ranger & B-Series 6 06-17-2013 09:39 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
