460 Swap - Ford Truck Enthusiasts Forums
460 Swap
Old 10-08-2012, 08:42 PM
Waylon Fan Waylon Fan is offline
Waylon Fan is starting off with a positive reputation.
460 Swap
I have a 65 F100 with a 240 6cylinder ..... I want to swap for a 460 with a C6 transmission.
Looking for info on motor mounts and transmission mounts and headers?
Thank you for you time!
Old 10-09-2012, 06:26 AM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
Read this thread http://www.ford-trucks.com/forums/11...gine-swap.html #3 has some detail info.
John
Old 10-09-2012, 11:59 AM
arctic y block's Avatar
arctic y block arctic y block is offline
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
http://i285.photobucket.com/albums/l...ghtsafter1.jpg
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Here's a tutorial Bob put together: http://www.ford-trucks.com/forums/67...-pictures.html
Old 10-10-2012, 07:31 PM
Quote:
John
I was looking to order part number TD-9720 from Dennis Carpenter do you know if this would work.
Old 10-11-2012, 09:20 PM
Old 10-11-2012, 09:43 PM
elgemcdlf's Avatar
elgemcdlf elgemcdlf is offline
elgemcdlf is gaining momentum as a positive member of FTE.
You want to find a complete set of mounts from a '73-'79 F series with a 460 assuming you have a 2x4. It is a bolt in with factory parts. Headers from the same truck should work as well. Same for the trans mount. You will need to move your trans crossmember back & drill new mount holes.
Old 10-15-2012, 10:17 PM
William William is offline
William is gaining momentum as a positive member of FTE.
The 460 Ford mounts show up on ebay once in a while. Assuming your deal is a 2 wheel drive truck 75-79? With the Ford mounts this is a bolt in deal. You will need the towers (bolt to the crossmember) The motor mounts (cross bolt type) and the cups that bolt to the block. Usually this stuff goes for about 100 bucks or less on ebay. I use truck or motor home exhaust manifolds plenty big enough and less problems than headers. IMHO!
Old 10-17-2012, 07:35 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by William View Post
The 460 Ford mounts show up on ebay once in a while. Assuming your deal is a 2 wheel drive truck 75 -79?
460: 1973/76 F100/350 / 1977/79 F150/350.
With the Ford mounts this is a bolt in deal. You will need the towers-bolt to the crossmember (D3TZ-6028-A Right D3TZ-6029-A Left) The motor mounts aka rubber insulators (D3TZ-6038-A Right/Left same).
The cups (D3TZ-6030-A Right D3TZ-6031-A Left) that bolt to the block. Rubber insulators bolt to these, then to the towers aka supports, perches, stands.
And....
D3TZ-6A023-A .. Rear Engine Mount Support aka cross member-bolts on / Same as 1973/76 F100/250 360/390 2WD & F350.
D3TZ-6068-C .. Rear Engine Mount Rubber Insulator.
Old 10-17-2012, 11:36 AM
RocketMonkey28's Avatar
RocketMonkey28 RocketMonkey28 is offline
RocketMonkey28 is starting off with a positive reputation.
If you're interested, I have some used headers. Actually two sets, one regular length, one long. PM me if interested, I can send pics and we can work out $ and shipping. I did this swap years ago, no regrets. Not that the FE isn't a great motor, but this is such a nice package.
Old 10-20-2012, 07:07 PM
tuffnufly81 tuffnufly81 is offline
tuffnufly81 is starting off with a positive reputation.
LMC has a complete motor swap mounting kit for 61-66 F100 for 429 and 460. I have ordered these since I could not find the perches from a 73-79 F250. I will let you know how these turn out. They are not stock of course.
Old 10-21-2012, 08:18 PM
pm042070 pm042070 is offline
pm042070 is starting off with a positive reputation.
I did this swap on my 1966 F250 2WD a few years back and it has worked out very well. I bought the perches and motor mounts from JEGS. I also had to upgrade the front coil springs and install heavy duty shocks to allow the front tires to align correctly. Headers from Hedman did work ok with slight modifications. With A/C from classic auto air it takes 3 electric fans on a 4 row radiator to cool the 460 engine with a C6 transmission and it is barely adequate but does do the job. Other than these few modifications everything has worked out pretty well. Your experience may differ. Best of luck to you!
Old 10-21-2012, 08:24 PM
I would recommend upgrading the alternator to a higher amp also if going with electric radiator fans. We so had to fabricate a heat shield for the power steering gear with the Hedman headers but wasn't anything major. Good luck again!
Old 10-21-2012, 09:01 PM
[QUOTE=NumberDummy;12381258]And....
Old 10-23-2012, 11:11 AM
Thanks everyone for the the feedback! I will order the materila from LMC. I have had the motor and trans on craig's list with no luck does anyone have any suggestions on selling the stock motor and trans.
Old 10-23-2012, 11:14 AM
Quote:
Rocketmonkey, I sent you a PM about the headers. I am new to the site so I may have messed it up....
360 to 460 swap f250 f25073 Engine Swaps 2 05-23-2016 12:33 PM
swapping the 460 engine Davie J. 1987 - 1996 F150 & Larger F-Series Trucks 1 09-17-2015 02:52 PM
351W to 460 swap TheMechanicalAnimal 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 62 05-07-2012 11:12 PM
5.4 to 7.5 joestang460 1999 to 2016 Super Duty 95 06-27-2011 03:23 AM
Motor mounts????? 562dragnhra Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 63 08-04-2009 07:29 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
