heater blows cold air - Ford Truck Enthusiasts Forums
Old 10-08-2012, 08:20 PM
JP Hobbit JP Hobbit is offline
JP Hobbit is starting off with a positive reputation.
Folks got a question and request for help. My 02 F150 V6 only blows cool air when set for heat. Did a bit of internet searching and factors involved. Radiator fluid is full. truck does not run hot (temp gauge shows normal), heater hoses=one gets hot the other feels cold when heater is "supposed" to be running. So I'm thinking it's either heater core is clogged or maybe heater control valve or blend door issue?? Any and all thoughts/advise would be appreciated.
Old 10-08-2012, 09:18 PM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Either the heater loop is clogged, the thermostat is bad, or the pump is weak.
Old 10-08-2012, 09:28 PM
Should have stated this as well. Had water pump replaced earlier this year so I doubt the water pump is part of the problem.
Old 10-09-2012, 07:14 PM
godsmkNH godsmkNH is offline
godsmkNH is starting off with a positive reputation.
did you have heat after the pump was changed out maybe or hopefully a air block ? just a thought
Old 10-09-2012, 09:38 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
If gauge is normal, then i would assume the thermostat is working also. I dont like the heater hoses, one hot, one cold idea. Im not sure there is a water valve on that truck. My 2001 5.4 has no valve. I think i would take both hoses off (heater) and connect garden hose to one end and flush thru good to see that if flows good... Also, turn the fan on very low speed, and the heater hose outlet should be about as hot as the inlet. Either no flow from heater pluggage, or some type of water valve.
Old 10-10-2012, 08:27 AM
Quote:
I learned a long time ago (the hard way, of course) that just because something is new(er), it cannot be assumed to be good.
Rear Heater Not Working ianobetz 1968-2013 Full Size Vans 13 02-24-2015 09:17 PM
Heater blows AC cold air F350-6 6.0L Power Stroke Diesel 10 11-04-2014 08:37 PM
06 F350 heater issue....help! wetnreckless805 6.0L Power Stroke Diesel 4 01-01-2013 02:23 PM
97 Ranger - turning on heater drops temp gauge to "C" R202INT Ranger & B-Series 1 03-03-2010 08:49 PM
1995 f150 heater core hot but blowing cold air wellys Cooling, Heating, Ventilation & A/C 5 04-07-2004 06:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
