C700 w/361 engine
Distributors
FT 361 should have the big oil pump drive shaft , this means a FE distributor will not work. If you want electronic ign the easy way is to install a Pertronics unit, easy and simple to install. Rule of FT's if it has the big diameter crank snout it has the big diameter oil pump drive. As far as the diameter of the distributor base goes FT and FE are the same where they fit in the intake, the difference is the oil pump drive diameter FT's are larger.
Have A Great Day -------- Hotwrench
FT 361 should have the big oil pump drive shaft, this means an FE distributor will not work. If you want electronic ign the easy way is to install a Pertronics unit, easy and simple to install.
C4TZ-6A618-A .. Distributor Drive Shaft = 1964/78 330 2V Heavy Duty, 361 2V & 4V, 391 4V FT engines.
1964/67 330 2V M/D uses the same crank as a 1964/67 FE 352 2V / 1968/78 330 2V M/D uses the same crank as a 1968/76 FE 360 2V
next time you go to start it cold have someone else do it and see where it leaks from i had a problem like that and it was where it bolts to the block....if that is all it is we won't know till you look .... if you weren't so far away i would just about give you my FT oil filter holder (don't know technical name for it) since i used one off of a 352 because i had some clearance issues also IMHO get an oil filter relocation kit they are only about $40 if it is indeed leaking from where it bolts to the block let us know when you can madrid
on
Sounds like really neat truck. And across the pond too. Ya got any pic's.
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
http://i285.photobucket.com/albums/l...ghtsafter1.jpg
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html
1. Login to FTE.
5. Click Upload.
Welcome to FTE!
Hope that helps.
OIL LEAK
I had a similer problem on a FT391 . What is your oil presure at cold start? What is it warmed up? The truck I was working on the pressure relief valve would stick when cold and then would release after a few minutes, it would blow out the filter seal , or leak out of the sending unit until the pressure dropped. This engine would have over 100 PSI. for a few minutes then would drop back to 60PSI cold . Hot ideling 35 PSI at 2000 RPM it had 55PSI. Cleaned the relief valve and no more problems.
Just Some Thoughts ------- Hotwrench
