C700 w/361 engine
#32
Does your FT engine have the boss for mounting the FE/330 M/D oil filter adapter that uses the FL-1A Spin-On oil filter?
#33
Sounds like really neat truck. And across the pond too. Ya got any pic's.
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
http://i285.photobucket.com/albums/l...ghtsafter1.jpg
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html
1. Login to FTE.
5. Click Upload.
Welcome to FTE!
Hope that helps.
#34
The filter standoff has a groove for the big flat o-ring (which is a pos pita to get back on after its sat in a package all wrapped up) then a large threaded hole for the big hollow bolt that holds the cartridge housing and spring and the other two gaskets against the element..
Is there a stub fitting or something that adapts the threaded hole to fit to a spin on filter that fits in the original o ring groove?
#35
i drained oil, it looked old & used. put in 3/4 gallon kerosene and some new oil; run engine for 1/2 hour. drained kerosene, replaced with new oil and oil filter. no blow by from filter on start up and oil pressure looks good, cross my fingers. this saturday's competion is on the otherside of the valley[20 miles] and will be returning late 9-10pm
#36
oil leaks around filter
pumped out 2 quarts before engine warmed up and stopped leaking. i don't understand how this is happening. oil pressure must be real high normally when you are revved up? why does it spew out at start up, oil too thick??
now i need to find an oil pan gasket and a oil pump gasket !!! Bill could you give me FT/FE cross over info ? and the part numbers. pan gasket i think is a 6710
#37
#39
oil change
funny isn't it; i change oil in a C700, but took my 01 Ford Escape in for lube-oil n filter...haha
told my grease monkey that i was blowing oil and he said u got to much oil....so i rush home get out my CD's and dig into maint. & lube section and find capacities and i was right, it takes 8 quarts of oil, so now i'm back to dropping oil pan and pulling oil pump. dang, i'm not lazy, but arthtitis n hernia sure can take the spirit out of you!!! Pep Boys special ordered gaskets for me, hope they the right ones
glenn 79
08-30-2020 12:20 PM
lalberts
12-04-2016 10:30 PM
mlevario99
04-26-2008 11:10 PM
big daddy chuck
12-09-2005 05:00 PM
big daddy chuck
11-25-2005 09:52 PM
