1971 C Series Brakes issue
Just a quick question, I'm hoping.
First off I have a C-700. 24,000 GVW.
The brake pedal has no pressure to it. At the very bottom of the press there is a significant amount of stopping power...but it all comes at once. Locks the tires up and tries to send you packing(out the windshield). I even noticed the driver side rear tires where locked up when I first started to move again. But once rolling they broke free.
What could be causing this? Im sure its a range of this. But I dont know where to start.
Thanks.
Also, Is there a service manual anywhere for these old trucks?
Thanks.
Brakes that are out of adjustment usually bind when they hit the drum because the piston has to move so far out of the bore that it can get tweeked in the bore, after a while it wears areas faster than others in the wheel cylinder which adds to the problem.. Eventually the wheel will lock up and not release..
Pulling the hub and drum are probably going to be the next step. But you can see if they just need adjustment.. May be that the adjusters are frozen after all this time though.
Justin Jones
05-01-2019 06:17 AM
lyonsfin
10-18-2017 03:49 PM
SonyResendiz
17
12-05-2014 09:29 PM
1968F100ShortBed
09-12-2010 10:26 AM
