Cranks but does not start - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 10-08-2012, 03:18 PM
pyro883 pyro883 is offline
pyro883 is starting off with a positive reputation.
Here's the deal. A few months back, I was driving to work and the check engine light started to flash like it was misfiring. About 2 weeks prior I had replaced the coil pack on the 2nd cylinder for misfire. While it was flashing misfire the car was bucking and would not go over about 10 miles and hour I stoped the car and turned it back on. The car started back up, and then started the same thing shortly after. I then turned the car off and tried it again, and this time it would only crank. Had it towed to the Ford dealer, where they told me the engine was bad, because they couldnt get it to rotate fast enough for a compression test. Had the motor rebuilt, and now still having the same issues with cranking but not starting. Had it taken to a new dealership and they replaced a relay, and the starter. Still cranks slow and no start. Had the crank sensor replaced and still no start. Recently threw a code for the flappers foer the intake, and when removed and bench tested the intake checks good. It is getting air and fuel, and says it's getting spark but still a no start. Anybody have any ideas? Would much appreciate it.
Old 10-08-2012, 09:17 PM
pdqford pdqford is offline
pdqford has a good reputation on FTE.pdqford has a good reputation on FTE.
Do a voltage drop from the positive battery POST to the + post on the starter. And do the same from the starter body to the negative POST of the battery. What are your readings?
Old 10-08-2012, 10:22 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Quote:
Originally Posted by pyro883 View Post
Had it towed to the Ford dealer, where they told me the engine was bad, because they couldn't get it to rotate fast enough for a compression test.
Surely you jest!
Old 10-09-2012, 09:20 AM
delano0512 delano0512 is offline
delano0512 is starting off with a positive reputation.
my thoughts are a clogged catalytic converter. This is just a hunch, but it would give you the issues you are talking about and may not throw a code. One way to test is to remove the cat, and crank the motor, if it runs fine, that's your problem. A couple of questions for you. Has the truck gotten wet on the inside? (bad ECM maybe) Has the truck been sitting for a while? (clogged cat, or bad gas.) When you try to start it is there any smoke coming from the tail pipe? Hope this helps lead you or one of the other form member in the right direction to find the cause. I'm sure you will figure it out, when you do share the knowledge.
NEED HELP. 1990 econoline 150 302 V8 wont start. vanking 1968-2013 Full Size Vans 15 05-20-2015 12:32 PM
2006 F-150 Misfire MLindsey75 2004 - 2008 F150 18 03-11-2012 02:43 PM
What could it be??? Still Smoking 2004 - 2008 F150 12 10-09-2010 10:18 AM
2006 Expy misfire Paul B 1997-2006 Expedition & Navigator 5 05-16-2010 09:29 PM
F150 engine shut down. tarzanjane 1997 - 2003 F150 2 09-17-2007 02:03 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
