Tranny fill plug ?
Old 10-08-2012, 01:55 PM
richdawg's Avatar
richdawg
richdawg is offline
Tranny fill plug ?
Anyone have any suggestions on how to get this out? A couple of years ago the guy that I had change the clutch thought he would check the fluid level F---d it up, I was shocked because I had it out just a few months before and I didn't tighten it as tight as it was when I got it out. I know I can fill it through the shifter but I would like to get it out.
Old 10-08-2012, 02:26 PM
Hussler's Avatar
Hussler
Hussler is offline
Rich, maybe a grinder to slot it ...
Old 10-08-2012, 02:35 PM
fordpride's Avatar
fordpride
fordpride is offline
Weld a bolt head to it.
Hammer and chisel
Old 10-08-2012, 02:46 PM
DIYMechanic's Avatar
DIYMechanic
DIYMechanic is offline
^^ 2X I would try a hammer and a small, sharp chisel. Get a bite on the outside edge of it and you should be able to get it to work loose. That is, as long as you can get a chisel and hammer in there to it...
Old 10-08-2012, 04:36 PM
helifixer's Avatar
helifixer
helifixer is offline
Received 3,626 Likes on 1,118 Posts
mig weld a nut on it. the heat will expand the plug and the aluminum case, let cool a few minutes and put a box wrench on it and remove it.
Old 10-08-2012, 08:57 PM
BuckHammer's Avatar
BuckHammer
BuckHammer is online now
Was the man who damaged it not honest and up front about the damage? If so, why didn't he make it right?
Old 10-08-2012, 09:26 PM
nomad221's Avatar
nomad221
nomad221 is offline
Are you changing the fluid ? If you are, loosen some bolts on the PTO cover and drain it.
Old 10-11-2012, 02:16 PM
richdawg's Avatar
richdawg
richdawg is offline
Thanks for all the comments. I think the best one is to weld onto it with the tig, but thats not an option for me as I don't have one or know how to use it.
Hussler i've thought of grinding a slot in it and may try that. If that doesn't work i'll go to the chissel and hammer. I do have access to an acetylene torch, would it be helpful to heat the aluminum around the plug or both or just the plug?l I would have answered this thread sooner but been out of town where I have no internet available .
Old 10-11-2012, 02:19 PM
richdawg's Avatar
richdawg
richdawg is offline
2wd Two short
Old 10-11-2012, 05:03 PM
madpogue's Avatar
madpogue
madpogue is offline
Slot makes the most sense to me, since it's sticking out a little from the surface of the case. Should be enough to cut a slot or two around the perimiter, deep enough so you can put a screwdriver or chisel in it at an angle and tap it with a hammer.
Old 10-11-2012, 07:24 PM
DIYMechanic
I wouldn't waste your time with the grinder and just get the chisel and hammer out. A sharp chisel will make its own slot and even with the slot in there I doubt you will be able to spin it out with a screwdriver. Plus the impact of the hammer and chisel will help jar it loose...
Old 10-11-2012, 09:01 PM
Talyn's Avatar
Talyn
Talyn is offline
Thats my suggestion.
duskrider
37
03-19-2018 08:34 AM
fdude64
09-04-2012 11:24 PM
mudslinging79
Bronco II
09-22-2009 11:59 PM
Ricache
08-18-2009 10:58 AM
mjk
08-15-2005 01:24 PM
Quick Reply: Tranny fill plug ?
