66 f100 352-429 engine swap
Hello,
My uncle gave me my dad's 66 f100for free. Its in really good shape with no rusting and only two dents. The 352 is locked up and I found a running 429 with auto trans for a deal. I was wondering what is needed to swap the 429 with the 352. I'm pretty sure the cross member has to be changed for the trans because it still has the 3 speed, but other than that what else would I need to change. Please help and info will be great
Thank you, Shane
Thank you, Shane
John, do you consider 1973 a "late '70's?" / F350 460 same parts as F100/250 460.
460 engine mounting parts same: 1973/76 F100 / 1973/79 F250/350 / 1975/79 F150 / Ford part numbers listed for clarity only, all are obsolete.
460 not available in F100's after 1976. F150 introduced in 1975 / ALL 2WD only / No 460's available with 4WD or a M/T until 1983. These engine mounting parts will not work on anything prior to 1980.
D3TZ-6028-A Right & D3TZ-6029-A Left .. Engine Supports aka towers, stands, perches.
D3TZ-6030-A Right & D3TZ-6031-A Left .. Brackets / These bolt to the block, the rubber insulators bolt to these, then to the supports.
2) D3TZ-6038-A .. R/L Front Rubber Insulators.
D3TZ-6A023-A .. Rear Engine Support / Some people call this a cross member, bolts to frame rails. Same as: 1973/76 F100/250 360/390 2WD & F350.
D3TZ-6068-C .. Rear Rubber Insulator.
No such thing as "numbers matching." Numbers matching is a GM thing.
You won't find a C4 behind any 429 or 460. 1968/73 429 & 1968/88 460: The only available A/T was the C6, has 17 trans pan bolt holes.
The only 1971 Mustang w/a 429 would have a Cobra Jet or Super Cobra Jet engine. Never mind the Mustang itself, there's no way on god's green earth, unless the seller is clueless, to buy a 429 CJ or 429 S/CJ engine for $600.00.
More than likely, the Mustang has a 302 or a 351C. 302 came with a C4 (11 trans pan bolt holes) / 351C could have a C4, C6 or an FMX (14 trans pan bolt holes).
Valve covers bolts per side: 429/460 = Seven / 302 = Six / 351C = Eight.
Do not believe a single word a seller claims! Private sellers lie just like used/new car dealers, lawyers, politicians and TV evangelists.
Any idea of how many 73s one would have to go through to find a 460?
John
In states where salt is used on the roads, probably difficult to find. OP lives in Arkansas, dunno if salt is used on the roads there.
Here in CA they aren't that hard to find, probably not that hard to find in TX either, as more of these trucks were sold in these two states than anywhere else.
Correct, but you cannot use F250 disc brakes on an F100, because F250's have 8 lug wheels on a 6.50" bolt circle. F250's front suspension also different, so you cannot use the F250's P/S on an F100 either.
