52 F6 - jumps out of then back into gear
Old 10-08-2012, 05:48 PM
hulaman's Avatar
hulaman
hulaman is offline
Hello all,
I have a 239 FHV8 with a T98 Tranny and dual speed rear axle.
Sometimes and usually at a slow speed and\or around corner it jumps gear and grinds from the rear as opposed to underneath me.
Because this dual speed axle is managed by the engine vacuum could the air compression be the issue as opposed to the transmission or gears in the axle?
Thanks,
hulaman
Old 10-08-2012, 09:49 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
You should have the highest vacuum going around corners or at slow speed, but it sounds likely the hose is rotten or something.
Gotanoldtruck
39
11-07-2016 03:52 PM
Bubba-88
08-22-2014 02:40 PM
awhtx
WTB - Parts & other
04-25-2011 06:20 AM
stang88
05-19-2004 11:18 PM
geoaigel
11-02-2002 08:40 AM
Quick Reply: 52 F6 - jumps out of then back into gear
