Just picked up a 96 F350 with a 460/ ZF5 trans with a Borg Warner 4407 transfercase. It is a a single wheel rear 1 ton. My question is what rear axle does it have under it?
It's a sterling 10.25 ring gear.
If you want to know gear ratio either post the door tag, or crawl under the truck.
There should be a metal tag on the bolts for the differential cover with the info on it.
