check engine light
Old 01-08-2013, 10:01 PM
Randall Ford's Avatar
Randall Ford
Randall Ford is offline
check engine light
How many sensors should I change after 90,000 miles. My light comes on at lower speeds, then goes off?
Old 01-08-2013, 10:33 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,164 Likes on 919 Posts
If you want to throw money away replace all of them. Otherwise why not check for codes yourself.
What year/model/engine/transmission vehicle are you referring to?
Old 01-09-2013, 11:21 AM
Randall Ford
check engine light
I guess I got worried when I saw the Chilton book suggesting that at least 4 of these sensors be replaced every 15,000 miles. I did actually go down and talk to a mechanic, he said it was the oxygen sensor, no worries unless you want to please the EPA. Thanks for your reply, Randall Ford (yes that is my real middle name)
Old 01-09-2013, 11:58 AM
rla2005's Avatar
rla2005
rla2005 is offline
The O2 sensor does more than keep the EPA folks happy, it will make your wallet happy too by delivering better fuel economy.
You really should get a handle on what code(s) are happening then repairing the root cause.
Old 01-09-2013, 03:06 PM
timbersteel's Avatar
timbersteel
timbersteel is offline
Yeah, a faulty O2 will cause many more problems one is wanting to deal with. Get a code reader, verify what is going on and if possible, replace sensors with Motorcraft parts, not cheap knock offs. You can even check for cods with a paperclip if needed too for free.
Jrock909
12-03-2004 08:10 PM
jdotoli
1983 - 2012 Ranger & B-Series
12-17-2003 01:53 PM
djexpi
1997-2006 Expedition & Navigator
04-27-2003 07:32 PM
big6
1997 - 2003 F150
13
02-27-2003 09:43 PM
PaulH
10-04-2001 01:55 PM
Quick Reply: check engine light
