how much can i tow
Just because your truck can get a weight moving doesn't mean it can stop that weight - legal max towing and payload ratings take that into account. Our trucks brakes were decent enough for the day but by modern standards they're not very good; that's why our ratings are (relatively) low and new trucks have much higher ratings.
To use a graphic example, the 15" wheels most of our trucks came with from the factory won't even fit over the rotor and caliper of a new 150. The 16" wheels might just barely fit, might not.
What you're looking at is a 3000 (for sure) pound tractor, 1500(?) trailer, and 5000(?) truck. Sorry, I've never weighed the whole rig. I'm not going to win any races, but the truck handles it with ease. And before you start in on me, the trailer has working brakes and we put proper tongue weight on, etc etc. It's not an unsafe load. I have hauled tractors up to 4500 pounds with no issues.
I doubt that truck is anywhere near 6000 pounds. My friend's '96 F-250 460 CCSB 4x4, with 31" tires, tool box filled with tools, subs, and him in it weighed 6560 pounds.
Those OBS F-150s could get very light. I believe RCSB 2wd models with the lightest engine (302?) could squeak in at around 4000 pounds.
hey guys my door tag does say 8650gvwr . ford told me today though that the gcwr is 6450.... i am confused. i could upload a picture of the door tag but i promise it says 8650 gvwr. the truck does have five leaf springs the heavy duty cooling system rear sway bar ect.... but i am confused i just want to know what it can tow and what is the payload.
GCWR=Gross Combined Weight Rating=Max weight of truck + trailer loaded
GVWR=Gross Vehicle Weight Rating=Max. weight of truck loaded
Something is mixed up here. 8650 GVWR is F250HD/F350. Check your VIN with this link GVW=GVWR
Truck Parts and Truck Accessories
i don't know the weight of the load but i know my 92 with a 302 and AOD-E 3.73 gears didn't have a problem pulling a 4 horse trailer and 3 full size overly healthy 16 hand tall bay's doing 65 right down the highway she wasn't straining hard at all i still refused to use overdrive in that situation though..... but since you have a manual it should do better and give you more options too
Thats odd. My CCLB 460 5spd truck weighs 7200lbs
And my reg cab short bed lightning weighs 4400lbs
Both with out me in them
#29
#30
Local scrap yard. Weights and measures is there every month to check accuracy. I cant remember full of fuel or not But 2 fuel tanks only weighs 250lbs. I know the lightning was published as 4400lbs so I know that is right on
