key for spare tire
key for spare tire
i have a 2008 crewcab with a locking spare tire,without key to unlock it,it let me setting with flat tire.called ford dealer to see if i can get a replacement key but said i was out of luck because they are a vender part and they can not help me.no use having a spare if l can not use it,does any body have any idea to get the spare useable. terry
Youtube is your friend Ford Pickup spare tire solution - YouTube
I've seen people do this with a regular socket and just hammer it on to the keyed insert.
Worst case, cut the cable, take out the wheel, remove the keyed insert, install new cable, reinstall spare wheel. Key no longer needed.
I'd say that at about 4:45 is the "cheapest" solution.
https://www.ford-trucks.com/forums/1...l#post12166626
When he talks about pulling the scoop/hood thingie I just twisted it to pull it off, although your mileage may vary. Mine didn't have a key... or the spare any more either.
9/16 socket on a long extension, pound it on the lock.
Crank the tire down with a ratchet, then pull out the extension. Socket will remain on the lock.
Remove the plastic tube. 1/4 turn and it will pull right out.
Reach up in there with a screwdriver and hammer and pop the lock out. No need to remove the winch from the truck like in the video.
Put the plastic tube back in.
Now you can raise/lower the spare tire with your jack handle.
NEVER had my spare tire off in 8 + years ! Any pre removal ideas ? sprays etc. Does this f 150 you tube apply to f 250 2004 models are they alike ? I have been thinking it would be a good idea to take a look and try to remove so IF I get a flat I could have ( already have done it ) better expierence in taking it off , not being stuck somewhere and dealing with all this crap ? BETTER to have done this before ! RATHER than on the job expierence.
Mike get your butt outside this weekend and take your spare down.
On the side of the road during a storm is not the place to find out that you do not have the Knowledge, tools or some other necessity to do the job.
Also tires age and the rubber deteriorates.
The consensus is that 6 years is the lifespan for a tire, used or not.
After that period of time the possibility of having a tire failure is enhanced.
When I get called out to assist a roadside failure and the owner does not have the items needed to remove the wheel IE; The key for a wheel lock (most often ),The winch key(Subject of this thread) or the rod for winding down the spare, then the cost escalates accordingly.
Being dumb (stupid) should hurt.
Since I can't hit people, I hit their wallet.
