Stock 09 Expy fuel milage - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 10-07-2012, 05:53 PM
Biscayne Biscayne is offline
Biscayne is starting off with a positive reputation.
Just curious. 50/50 city/hwy, the stock 2009 expedition 4wd is getting 15 mpg solid. No give or take. 90,000 miles on the odometer, just curious is this approx. what you guys are getting? Time for plugs? Current on air, oil and trans fluid changes, I seem to remember getting 17 when we first got it. Any advice?
Old 10-07-2012, 10:57 PM
rayofsi rayofsi is offline
rayofsi is starting off with a positive reputation.
are you using ethanol free gas?
i think thats pretty much atleast 10% of someones gas mileage, i get 13mpg with a heavy foot, and 10% ethanol gas.
Old 10-08-2012, 08:30 AM
ray, no, the only gas available is 10% ethanol. My wife drive it a majority of the time and she does not have a lead foot.
Old 10-08-2012, 01:15 PM
Quote:
wow that is some good mileage then!
2wd mode or 4 auto?
my leadfoot probably accounts for the mileage loss.
Old 10-08-2012, 06:00 PM
4 wd automatic. I just was fishing to see if anyone changed their plugs and wires around the 90K mile mark and if it helped them. I am at a loss for the drop in milage we have seen.
Old 10-08-2012, 09:44 PM
Papa Tiger's Avatar
Papa Tiger Papa Tiger is offline
Papa Tiger has a very good reputation on FTE.Papa Tiger has a very good reputation on FTE.Papa Tiger has a very good reputation on FTE.
Usually it points to a partially clogged exhaust, possibly a pipe rusted off in the muffler or Catz, causing some back pressure hurting mileage immediately. A tune up and new exhaust probably will help a lot. You may be with the winter blend already? Don't know if your state has mandatory ethanol labels on the pumps or not and the way they do it in the fall. Tires could use a little air in em too?
Old 10-11-2012, 07:55 PM
winter blend makes sense, the milage started dropping around the same time my diesel did. i know we share the same supply lines as much colder areas than coastal NC and it always seemed rediculous that we would have the winter blend stuff here. Oh well, I had no idea gaasoline did it as well. On the other hand....I have been wanting to redo the exhaust anyway.
Old 01-17-2013, 07:57 PM
TCAS007's Avatar
TCAS007 TCAS007 is offline
TCAS007 is starting off with a positive reputation.
We have temperatures between 30 and - 10 here and since this winter my MPG dropped to 14!!
I am not happy and Ford has no solution. 85 K miles and all services done at Ford.
So what should I check?
I get 91 octane gas.
Old 03-27-2013, 05:37 AM
TCAS007's Avatar
Nobody got any ideas?
Old 03-27-2013, 12:24 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
That's normal mileage. Check tire pressure, air filter, fuel filter, clean MAF sensor, etc. Driving habits, etc. It's a 6,000lb vehicle.
Where to buy stock 390 heads? kadrocker FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 11 02-21-2016 12:46 PM
Largest tires for 15x8 Rims - Stock 1979 4x4 skips69 Brakes, Steering, Suspension, Tires, & Wheels 5 08-02-2015 07:13 PM
5.0 Muffler Suggestion ddh1 2009 - 2014 F150 13 05-22-2015 08:24 AM
89 crown vic 5.0 in a 85 f150 efi captain1997 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 16 11-15-2014 01:04 PM
What was the stock instrment cluster bezel made of? clintonvillian 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 09-21-2014 07:08 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
