cigarette lighter problems - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 10-07-2012, 03:13 PM
lookthepart lookthepart is offline
lookthepart is starting off with a positive reputation.
hello:
just got a 2003 e250 club van. it has the cigarette lighter socket as well as the data socket.
the cigarette lighter works in its socket but nothing else will. the data , nothing.
changed the fuse , checked the wire ,cleaned the sockets.
any info on a fix??
thanks in advance
Old 10-07-2012, 06:32 PM
joshofalltrades joshofalltrades is offline
joshofalltrades has a good reputation on FTE.joshofalltrades has a good reputation on FTE.
i know in the older body style, the wire powering the cig lighter port was short enough that it usually came unplugged whenever the panel was removed. i don't know if thats an issue in the newer vans.
what you should do is test to see if the contact in the center has power AND if the outer body of the socket is grounded. a simple test light can do this for you. from there, a problem on power getting to it can be bypassed with a new wire going through a fuse to the battery or distribution block. if its a ground problem, just run a new wire from the ground side of the socket to a good clean piece of steel thats grounded.
if both seem to be connected, your problem could be a dirty/corroded socket, which can be replaced for pretty cheap at your local parts store
How to remove the cigarette lighter whiteboyslo 1987 - 1996 F150 & Larger F-Series Trucks 7 11-08-2014 06:03 PM
Cigarette Lighter not working, fuse is fine MrShake 1999 to 2016 Super Duty 8 08-24-2012 10:47 AM
cigarette lighter socket removal eysham 1999 to 2016 Super Duty 13 02-01-2007 02:28 AM
2002 explorer cigarette lighter electrical wiring diagram dswong01 Explorer, Sport Trac, Mountaineer & Aviator 2 12-27-2006 12:06 AM
cigarette lighter questions (intermittent grounding, etc.) eclectix 1967 - 1972 F-100 & Larger F-Series Trucks 11 08-18-2003 01:29 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
