Spare Key - Ford Truck Enthusiasts Forums
Spare Key
Old 10-07-2012, 01:27 PM
Tim Young's Avatar
Tim Young Tim Young is offline
I'm just Deplorable!
Tim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputation
Spare Key
So what is the deal with the keys, is it possibly to have a key made that just opens the door and starts the truck? My current key has all bells and whistles. I'm hoping I can just take the key I have to the dealer and have another made. I am looking for a key that I can hide on the truck somewhere in case I loose the one in my pocket.
I see something in the manual about having a little bar code tag in case you have lost your keys, either I never got that tag or I have already misplaced it not knowing I needed it later.
Old 10-07-2012, 01:52 PM
rob92761's Avatar
rob92761 rob92761 is offline
rob92761 is starting off with a positive reputation.
I have a hide a key that will open door put will not start truck because it is not code.
Have another key that is coded but does not have the lock unlock doors on it.
If you have two keys now you can by another key from dealership and have that key learned. It is real easy and is in the owner’s manual on how to do it
Old 10-07-2012, 02:06 PM
Tim Young's Avatar
OK Thanks, I was concerned about the fact I do not have the bar code label that was suppose to come with the keys. Maybe it is just for all of the programmed stuff that the key can do, such as lock, unlock and remote start.
Old 10-07-2012, 09:07 PM
CornTruckDriver's Avatar
CornTruckDriver CornTruckDriver is offline
CornTruckDriver has much to be proud ofCornTruckDriver has much to be proud ofCornTruckDriver has much to be proud ofCornTruckDriver has much to be proud ofCornTruckDriver has much to be proud ofCornTruckDriver has much to be proud ofCornTruckDriver has much to be proud ofCornTruckDriver has much to be proud ofCornTruckDriver has much to be proud of
When I got my truck the dealer gave me a spare key.I just assumed it would start the truck. I guess I should try it. Maybe he did, IDK. I have the keypad on the door so it should start it.
Old 10-07-2012, 09:23 PM
cummins cowboy's Avatar
cummins cowboy cummins cowboy is offline
cummins cowboy is gaining momentum as a positive member of FTE.
looks like you have the king ranch model, that one should have the combo lock on the doors. I use mine quite often. its nice when my hands are full but a finger can be used to open the truck and I don't have to dig out my keys and set down whats in my hands.
Old 10-07-2012, 09:53 PM
my996duc1's Avatar
my996duc1 my996duc1 is offline
my996duc1 is gaining momentum as a positive member of FTE.my996duc1 is gaining momentum as a positive member of FTE.
I had a spare non coded key made to keep in the center console.
I keep my tailgate locked and haven't converted it to work with the power door locks yet.
I found myself with the truck running and needing into the bed of the truck, so the key saved me from having to shut the truck off just to open the tailgate.
The non-coded key will also turn on the radio. So if the wife wants to go wait in the truck, she can use the keypad on the driver's door to get in and the key in the center console will turn on the radio but it will not start the truck.
_
Old 10-07-2012, 10:31 PM
Adventure Rider's Avatar
Adventure Rider Adventure Rider is offline
Adventure Rider is gaining momentum as a positive member of FTE.
When I got my truck I was presented with two sets of keys.
The second set had a small bar code label on the key ring
Maybe follow up with your dealer if you didn't get your bar code info
Old 10-08-2012, 12:15 AM
Chad149's Avatar
Chad149 Chad149 is offline
Deplorable
Chad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputation
You need a PATS key. Its thirty to fourty bucks at most dealers around hear. I belive our included keys are about a $150.00.....
Old 10-08-2012, 05:38 AM
What's a PATS key?
Old 10-08-2012, 07:51 AM
uscgmkcret03 uscgmkcret03 is offline
uscgmkcret03 is starting off with a positive reputation.
You can get a key made at a locksmith with out the lock/unlock buttons on it, when you start the truck you will get a start system fault on message screen,they were suppose to fix that from happening I was told, hit ok and off you go, about $40 up here, It will set off the horn honking if you use it to unlock door but just start it up and it will stop the horn.
Old 10-08-2012, 04:14 PM
lundman lundman is offline
lundman is gaining momentum as a positive member of FTE.
key
I had a henweigh made and it does everything but start the truck so it is perfect to get in and out and unlock the tailgate, etc.
Old 10-08-2012, 05:27 PM
mr176 mr176 is offline
mr176 is starting off with a positive reputation.
I ordered a key through the dealer parts department without the remote lock/start functions and programmed it to start the truck myself. As long as you have two existing keys, the programming is a simple procedure and is outlined in the owners manual. The key blank from the dealer was cheaper than the local locksmith.
Old 10-08-2012, 05:39 PM
Tim Young's Avatar
I just checked with the dealer, $150 for the key with all of the buttons for the remote start, plus $40 for them to program it. A chipped key just to start the truck I think he said $50 and I can program.
I was mainly thinking that if lost my keys while out exploring or whatever I would have a key hidden to be able to drive home. I will probably go with just a coded key without all of the bells and whistles.
As far as the Bar Code thing that I don't have, it had the key code on it that would help in making a new but the dealer can make a new one without the code, so not a real big deal. They are working on getting me the key code so I will have it in case I need it in the future.
Old 10-10-2012, 07:59 PM
Chad149's Avatar
Deplorable
Quote:
Originally Posted by Adventure Rider View Post
What's a PATS key?
Passive Anti Theft System I think. Its just what Ford calls there anti theft (chipped) keys. Been using them for some time now. Just the last few years they started combining the remote fob into it but the transponder functions the same.
Remote start question.. AzPete 2009 - 2014 F150 8 03-22-2016 08:20 AM
Making a second or third transponder (PATS) key. EXv10 Excursion - King of SUVs 8 03-04-2014 09:10 AM
Is there a chip in the key? Fastback460 1987 - 1996 F150 & Larger F-Series Trucks 11 12-21-2013 04:26 PM
Spare Key BigNiner19 2004 - 2008 F150 13 04-05-2011 07:45 PM
Transponder keys Way Too Big Dectek 2004 - 2008 F150 7 02-15-2007 10:19 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
