302 EGR connection - Ford Truck Enthusiasts Forums
302 EGR connection
Old 10-07-2012, 01:37 PM
old farmer old farmer is offline
old farmer is starting off with a positive reputation.
302 EGR connection
It looks like I'm going to have to put EGR and a vapor canister on my 47 truck.
The smog police are now charging people for lack of equipment, based on the casting number on the block. Since mine starts with D4, it's a 74.
Two questions,
Can anyone tell me what the vacuum hose routing for the EGR system is, and also the vapor canister?
Also, I have the EGR plate but my manifold is from the 60's so it doesn't have the port in the carb flange for the plate. Would it be possible to drill a hole in the flange so the plate can get exhaust gas to make the EGR work?
Thanks.
Old 10-07-2012, 06:55 PM
Beanscoot Beanscoot is offline
Beanscoot is gaining momentum as a positive member of FTE.Beanscoot is gaining momentum as a positive member of FTE.
EGR
For emissions routing, I would look for a 1974 shop manual. But perhaps you could use the casting number off of the intake manifold to date the engine. After all, it is extremely difficult to see the block casting number on an installed engine, so the emissions inspector might be willing to accept the intake manifold casting number.
Old 10-08-2012, 11:21 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Quote:
If your intake doesn't have the EGR flange it's also doesn't have the internal EGR port down to the heads so you're probably SOL here without changing the intake. But the EGR valve doesn't need exhaust gas to work it just needs engine vacuum, so if you can mount it where it should be and connect vacuum nobody will be the wiser.
Part No. for Vapor Canister? GuitarJesus 1987 - 1996 F150 & Larger F-Series Trucks 0 03-24-2014 02:03 PM
emissions equipment V10man 1973 - 1979 F-100 & Larger F-Series Trucks 26 04-16-2013 07:02 PM
2000 6.8l Vapor Canister/Purge Valve Question - smells gas at idle. delzy Excursion - King of SUVs 1 06-25-2012 07:05 AM
Vapor canister? Dennis S Ranger & B-Series 3 04-27-2011 08:34 AM
What to do with vapor can vent line? a040599 1973 - 1979 F-100 & Larger F-Series Trucks 17 06-16-2007 03:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
