1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Fuel vent hose on F450???
Old 11-11-2012, 05:54 PM
john11139's Avatar
john11139
john11139 is offline
Help. I have a 2003 F450 6.8 L. It has a utility bed on it. I have not had it long. Every time I try fo fuel it up, it takes forever, shuts the nozzle off. And I can only get about 1/2 tank full. I crawled under there and got to checking if for kinks or something. I was feeling around and found the vent hose stuffed back on top of the tank, and had a plug in it. On most all Fords I have had the vent hose runs up and connects to a fitting comming off the fuel inlet. There is no nipple on this one to connect it. Could this just be run somewhere else and pointed down so water does not go up in it, or is this a preassureized tank that should have a valve. I am thinking they used the wrong filler neck. Any one with a F450 and a utility bed, could you look under it and see how your vent tube is hooked up. Please.Remember this is a diesel and when fueling it up I think with no vent it was just foaming up.
firehawk618
13
12-01-2018 07:37 AM
Birken Vogt
12-06-2016 09:54 PM
mfire138
11-09-2011 08:49 AM
82andBlueF150
05-07-2005 09:50 PM
Swampdonkey09
12-03-2003 08:09 PM
Quick Reply: Fuel vent hose on F450???
