My 02 Mountaineer doesn't have any air flow volume out of the heat, defrost, or a/c vents. The temp will change from hot to cold and the air direction will also change from floor, dash, windshield, ect. The a/c recirculation door also seems to be working. The fan sounds as it is running very fast, just not putting out any volume. What should I look for? Thanks
Fan is blowing fine at every speed, there has to be blockage somewhere that is not allowing the fan to get enough incoming air or a door that isn't completely opening, thus preventing full air flow. Was kinda of hoping someone that has had this problem before would chime in! Thanks
