Radiator support, Fix or replace?
I have a few pics in my gallery on how I fixed mine. It wasn't as bad, but the patches that I made seem only slightly smaller than your area of damage. It seems that if you don't have time to fix yourself, you probably wouldn't have time to install the replacement that you purchase.
That core looks very salvageable. I'd suggest since you have it out, try the fixit route taking nibbles of time here and there. If by Dec you don't have it fixed, then get the replacement. Good luck
the only places where I found layers were where the sections overlapped as in this picture.
What I did here was put in a peice from the front - I already had the front cut away. I welded that inside peice from the inside (accessed from front), then rust encapsulator. Finished up the front section after.
I don't recall running into 3 layers though. Forgive me for asking, but could that 3rd layer that you are seeing be rust scale?
66 grilles are wanted and I could not hold one for very long. You'll never get one for that price unless you hunt it down and remove it yourself.
The 62 63 64 core supports just are'nt in demand. So I got rid of what I had.
65 66 f100 2wd core supports are worth $$$$
Applications: 1961/64 F100/250 2WD/4WD / 1961/66 B500/600 (school bus) / 1961/66 F350/600 / 1965 F100/250 4WD / 1966 F250 4WD
NPD in Ventura, Blue Oval in Anaheim, Truck & Car Shop in Orange should have it, so you could whiz over and buy one, no shipping charges.
If I come across a good one soon I'll grab it for you. Even if you don't want it I can still get rid of it.
ihcc104
06-21-2016 09:41 AM
dan_s_johnson
1997-2006 Expedition & Navigator
16
11-15-2015 05:56 AM
Matt300ZXT
05-12-2009 06:32 PM
