warning light come on "brake'?
Unplug the switch at the proportioning valve, see if the light goes out. If it stays on, there is a wiring problem.
If you did a repair and the light is still on, the valve needs to be centered. Crack open one of the bleeder valves on a front wheel. Slowly depress the brake pedal, if the light goes out, stop. Close the bleeder valve and check to see if the light stays out. If the pedal reaches the floor but the light doesn't go out, repeat the same procedure on one of the rear wheels.
and n had not repair for brake before..
It can't. These Fords didn't have a parking brake warning light, there is no switch for it.
The only thing the "BRAKE" warning light indicates is a problem with the hydraulic brakes system. Technically what it indicates is an imbalance between the front and rear brake system pressure.
Applications: 1968/79 F100/350, Bronco & Econoline / 1968/69 FoMoCo Passenger Cars.
This plastic switch is a POS, develops cracks in its threads causing brake fluid to seep out.
When this occurres, the low brake fluid warning lamp on the dash comes on...and stays on!
boggerted
02-24-2008 06:27 PM
cigarxtc
03-21-2005 04:54 PM
Jag Red 54
10-26-2004 07:10 PM
sparkymazda01
1983 - 2012 Ranger & B-Series
11-08-2003 07:41 PM
