Gear Ratio - 1951 F1
Gentlemen,
I am getting ready to sell (or more likely give away !) the original rear end that came in my 51 F1. The limited shop manual, books etc. that I have lists a 3.92 as standard and a 4.27 as the option. So I set about to figure which one I have. By the way, no glove box door or any other codes on the truck anywhere.
So my understanding to determine the ratio is;
Block one side from turning
Rotate the free side 10x
Count the revolutions of the driveshaft. (I got about 17.5 on many tries.)
Double the 17.5 to get 35 indicating a gear ratio of 3.5 ! This does not seem right to me ? Maybe I did something wrong, however, I have used this method on other rear ends and came up with the correct answer. I have no indication that the rear end was swapped out but that is certainly possible.
Open to any thoughts on this. Will try to include a picture.
The following users liked this post:
Gentlemen,
Gentlemen,
It is unanimous! I have an approx. 3.5 rear gear. Both of the methods listed above, and my earlier method, all say it is a 3.5. (No identifying tags on the rear end.)
So, now that I am the proud owner of such rare and exotic hardware - Will this allow me to retire in luxury ?
Thanks to all !
Thanks to all !
Just to clarify what Ross said when both wheels are off the ground BOTH tires need to be turned in unison for one revolution while counting the pinon revolutions. It would be hard to diferentiate between 3.5 and 3.7 gears without putting marks of some kind on both tires and the pinion. Like stated, if your giving it away you might as well pull the cover to verify your need learned skill.
Gentlemen,
Thanks to all !
Thanks to all !
iburman
05-04-2020 09:13 PM
49willard
03-12-2015 08:16 PM
HILLBILLY BOB
01-28-2010 11:17 PM
