2011 3.5EB severe black smoke
Hi All, my first time posting here....very nice forums! I have a 2011 F150 XLT with the 3.5 EB. I have noticed the tailpipe is covered with black soot for some time now. The other day I went to pass a slow moving car, dropped the accelerator to about 3/4 throttle. The truck kicked into passing gear and the engine began to rattle similiar to being out of time or too much fuel. Passed the car and look back and a HUGE cloud of black smoke. No warning light came on and the truck seemed to run fine. Went a few miles further and passed another car.....same thing. Now I am concerned. At the base of a long steep hill I slowed done to about 40 and punched it, watching in the passenger side mirror only a small puff of smoke this time. Did this several more time and no more smoke. Called the dealer and got the run around....saying I needed to blow out the carbon. My thoughts is this isnt a 70' vintage carburated vehicle. The fuel meter is computer controlled and this shoudnt be happenning. I guess I will try some injector cleaner and see if that hepls. Any one else heard of this problem. Thanks
Craig
Thanks for the responses. As for the weather that day, it was clear with low humidity and around 65 degrees. I have been driving the truck harder than before and have not had this problem since. Regarding the fuel....that poses an interesting question. We all know that ethanol is problem and can kill milage. I work in a refinery and know first hand the damage ethanol does. Nearby there is another refinery and they are blending liquid Butane into there gasoline. It is a byproduct and this is the easiest way to get rid of it. So, when I buy fuel it is a 50/50 chance that it came from the refinery that blends butane. I can tell by the odor who made the gas. Just some food for thought on fuel and performance.
The TSB is 12-10-19 and replaces the CAC's in those trucks already built.
It also looks like the new trucks are coming in with yet a third version of CAC with different connections and ports (which couldn't be retro fitted to existing trucks)<!-- google_ad_section_end --> <!-- / message -->
<!-- sig -->__________________
The Ecoboost is direct injected and direct injected gasoline engines sometimes have issues with coking. They build up a lot of carbon around the injectors and valves, which sometimes breaks loose and burns off.
Audi has had problems with this for years:
Audi FSI Engine Carbon Build-up Megathread
In some engines it can get bad enough to cause problems, but as long as the truck is running fine now I wouldn't really worry about it.
