>10% Fuel Dilution
>10% Fuel Dilution
On the road. Had oil changed in Wichita. Pulled a sample and sent it to Blackstone Labs.
Lab results caught up with me in Arkansas. Currently in San Antonio.
Aluminum, iron, molybdenum and magnesium content were also up (31, 96, 57, and 1069).
This was the second oil change on the truck. Oil, Rotella T-6, had 7,000 miles on it. Truck had 12,100 at time of change.
Keeping a close eye on oil level. So far, no discerenable increase in level.
And if this wasn't enough to keep my mind occupied, the truck was broken into night before last, while parked in the Airport Hilton Parking lot. They used some sort of pry tool in the door lock, based on the mark on the bottom of the key hole, and bent sheet metal...insert tool, press down hard. Open door and select from a variety of goods...
Any thoughts here? (About the oil issue)
Bob
Bob
You should not have greater than 10% in 7,000 miles unless you idle all day.
I've never heard of this number with the 6.7L.
7% is where you need to be concerned per one of the engineers who used to post here.
https://www.ford-trucks.com/forums/1...ml#post9456549
