smells like burning wires when driving up hills - Ford Truck Enthusiasts Forums
Old 10-05-2012, 02:29 AM
joshofalltrades joshofalltrades is offline
joshofalltrades has a good reputation on FTE.joshofalltrades has a good reputation on FTE.
my e350 is running great, but for a few weeks now, i've noticed that i get a nasty smell when driving up long hills, especially at highway speeds. usually its a certain mile-long hill i usually take at 70-75, but it happens in other places too. the smell strongly resembles hot wiring, though that makes no sense.
i checked for any wires close to the exhaust and found none, and nothing else on the truck would have a reason to heat up for working the engine harder.
any ideas?
Old 10-05-2012, 03:01 AM
SnuffthePunkz's Avatar
SnuffthePunkz SnuffthePunkz is offline
SnuffthePunkz is starting off with a positive reputation.
Does it kinda smell a bit like a worn out V belt?
I have the same issue during the summer, and it goes away in the winter.
I figure it has something to do with the temperature in the engine bay.
Old 10-05-2012, 03:12 AM
i know what a belt smells like, and i know what burning wires smell like. this smells a lot more like wires.
a few months back i burned off a brand new belt for my second alternator, so that smell is quite familiar to me, and doesn't appear to be what i'm smelling here.
i'm not sure so much if it relates to the temp of the engine bay, or the exhaust temp. the exhaust temp almost seems more likely, as it happens whenever i'm working it hard, but without a gage to know that it only happens above ****, that remains in the world of speculation.
i do know that the coolant temp remains constant at 195-200 when this is happening, so thats not a factor
Old 10-05-2012, 05:26 AM
hookedondiesel hookedondiesel is offline
hookedondiesel is gaining momentum as a positive member of FTE.
I'll take a stab in the dark,...since your going up hill....
Fluids are "angled" maybe something's shorting, when they are.
Bad Injectors? Firefighter6601 1987 - 1996 F150 & Larger F-Series Trucks 1 07-30-2015 10:57 AM
Burning smell while towing uphill fyrmnk1 1999 to 2016 Super Duty 10 06-20-2015 05:27 PM
codes 95schauf 1994.5 - 1997 7.3L Power Stroke Diesel 3 10-08-2012 11:01 AM
Coolant smell in cab but dont see any leaks..... Robby Nash 1999 to 2016 Super Duty 10 07-18-2012 08:55 PM
Engine smells when towing up BIG hills sean23johnson 1999 - 2003 7.3L Power Stroke Diesel 10 12-01-2010 04:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
