buying a 1942 Ford P/u
Hi, First day, first post. Apologies if I'm in the wrong place. I'm in the process of buying a 1942 Ford P/u. It was owned by a film company and they have lost the registration. Can you help me by telling me where on the vehicle that I can find the serial #, so I can get a new registration? I am in Langley BC, Canada.
I purchased the truck that was used in the film TinMan, a remake of the Wizard of Oz
Received 1,353 Likes
on
x2 drivers side frame right by the steering box.. might have to use some dish saop and brillo pad to remove the oxidation/rust to see it. take a white crown and rub the area.. then wipe it clean with a towel and it will leave the wax from the crown in the set marks from the factory.. easy to read after that point..
Thank you all. Took a while, but finally got the truck. I am not a mechanic, not handy with tools and am looking for advice. I would like to change out original brakes and have someone install disc brakes on front and new brakes on the rear. Can anyone give me a ballpark $ figure? I will not be doing it myself, I need to farm it out. 1942 Ford flat deck 1 (3)? ton. also does this vehicle have widowmakers? I'll probably have to put on new wheels and rubber if it does
What model is the truck? One ton, three ton? Pictures would help guys aim you in the right direction, and as said, finding the frame and/or bell housing stamped serial number is the absolute answer. No matter which model, a 1942 truck did not begin life with widow maker Firestone RH-5° wheels. But, depending on which model it is, they could have been substituted at some point over the years of prior ownership. Again, pictures would help. Stu
Mark_1042
07-04-2016 02:59 PM
James_Western_Canada
03-08-2016 07:50 PM
Samsn4
08-25-2012 05:57 PM
