p0308 engine code 09 f150 - Ford Truck Enthusiasts Forums
Old 10-05-2012, 12:12 AM
f150 all the way f150 all the way is offline
f150 all the way is starting off with a positive reputation.
My 09 f150 pulled a p0308 cylinder 8 misfire code the other day. it has 90,000 miles on it and idk what to look for. I have checked the coil and its fine. im replacing plugs tomarrow hoping that it but i needed some info. It did it after i left the car wash and i guned it and the light started blinking then went off later on so the next day i tried to see if it would do it again and sure enough it did it started shaking when i let go of gas and lost power but sometimes it work perfectly fine and drives completely normal. WHy does it keep pulling the code and acting weird then i try it some other time and its fine...
Old 10-05-2012, 05:57 AM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
There's no way to tel if a COP (coil over plug) is good or bad just by looking at it. You're likely misfiring because of a bad COP.
Old 10-06-2012, 01:16 AM
i switched the coil pack 5 and 8 and it still showed the same code
Old 10-06-2012, 01:25 AM
i was trying to check the wire from the coil today to see if it was bad cause the light keeps going on and off. could it be one of my sensors?
Old 10-06-2012, 06:18 AM
D8chumley's Avatar
D8chumley D8chumley is offline
Resident smarta$$
D8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud of
Thats the way my old 04 F250 5.4 work truck acted when a COP was going out( had well over 100k when this started IIRC). It would run OK then fall on its face. It happened to 2-3 other COP's before I "persuaded" our shop to just change the rest of them out, I was tired of bringing my truck in for a loaner every 3-4 weeks. Welcome to FTE, lots of friendly, knowledgeable folks here
Old 10-06-2012, 09:23 AM
thanks you so you think all of them are going out since i switched 5 and 8
Old 10-06-2012, 09:44 AM
D8chumley's Avatar
Resident smarta$$
No, I'm not suggesting you buy all 8. You could, I suppose- if you wanted to. I was just relaying my personal experience. I had 3 go out over the course of 3'ish months. That doesn't mean it would happen to yours
Old 10-06-2012, 09:49 AM
ok thanks could it be the plug by any chance if that not the problem or could it b the engine
Old 10-07-2012, 09:09 AM
D8chumley's Avatar
Resident smarta$$
Id start with the COP and go from there. I doubt its the engine. Keep us posted with your findings
Old 10-08-2012, 07:27 PM
ohboy44 ohboy44 is offline
ohboy44 is starting off with a positive reputation.
If the coil was bad the misfire would follow it.
I would check the spark plug, it probably got water in the well and cracked the ceramic. You will see a black line (carbon track).
2002 E250 5.4 starts out running fine, crawling in 10 minutes Ryan Simpson 1968-2013 Full Size Vans 15 04-12-2016 07:53 AM
Codes Codes P0308 and P0171 5.4Triton 1997 - 2003 F150 15 03-30-2012 08:36 PM
Still can't figure out code P0308 cly 8 missfire RKR 1997-2006 Expedition & Navigator 25 01-17-2012 06:31 PM
05 with p0300 code amd916002000 2004 - 2008 F150 2 01-29-2009 09:04 AM
P0308 code jwillyf150 2004 - 2008 F150 10 08-18-2008 09:10 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
