2010 F150 4.6L slow to fuel
Old 10-19-2020, 03:56 PM
cdubb79w's Avatar
cdubb79w
cdubb79w is offline
So it takes me a half hour to fill my tank, pump will constantly kick off if it’s more than an 1/8th pump speed. Tried different stations, pulling the nozzle out as far as possible, turning the handle sideways and no change. Two weekends ago I pulled and cleaned the vent line on the filler neck as well as the line going to the charcoal canister and my fuel mileage improved (1.3mpg higher) but still is painfully slow to fuel.
Next issue to check would be the charcoal canister correct or is there another spot that will cause this? Fuel tank itself is not deformed in anyway, when I cleaned the vent lines out there was some junk in them so I had high hopes that would fix the issues.
Thoughts?
Old 10-24-2020, 08:14 PM
cdubb79w's Avatar
cdubb79w
cdubb79w is offline
Bump, someone has to know
Old 10-24-2020, 10:40 PM
gDMJoe's Avatar
gDMJoe
gDMJoe is offline
Arrow
Sounds as if there's been TOO many fill-ups beyond the initial click-off of the fuel fill nozzle. *meaning: soaked canister.
Old 10-25-2020, 01:07 AM
CathedralCub's Avatar
CathedralCub
CathedralCub is offline
I tend to agree with gDMJoe ^^^^^^^, it sounds like possibly the cannister is soaked. Take it out, is it light or heavy?
You could also shine a flashlight down into the filler and see if there is anything weird going on.
Does your area have pumps with the vapor-collector boot on them? If so, you could try pulling one side slightly away from the filler neck so there isn't a seal and see if that helps.
Old 10-25-2020, 04:37 AM
rbentnail's Avatar
rbentnail
rbentnail is offline
I was thinking the same thing- maybe it's time to start removing/inspecting/replacing venting components.
King808AG
12-23-2016 02:42 PM
anthrax91
08-29-2014 05:08 PM
JohnDigger
06-15-2013 12:35 PM
cadunkle
10-26-2009 09:19 PM
wcsd106
02-09-2008 01:13 PM
Quick Reply: 2010 F150 4.6L slow to fuel
