2001 Supercrew and Courtesy Light issue - Ford Truck Enthusiasts Forums
Old 10-04-2012, 01:01 AM
Wathen1955 Wathen1955 is offline
Wathen1955 is starting off with a positive reputation.
I have a 2001 F150 Supercrew. On the passenger door, the courtesy light no longer comes on. It's the light on the door (not the doom light). If I open any of the other 3 doors, all of the lights come on including on the passenger side so I know the bulb is good.
I looked for a door switch, but did not see any along the door or frame of the door. How do I go about fixing this?
Old 10-04-2012, 03:26 PM
LOL - should have used the search feature first. Found it here:
http://www.ford-trucks.com/forums/19...or-switch.html
No wonder I could not find it. It's part of the door latch.
Old 10-04-2012, 08:07 PM
That still did not work. I sprayed both the latch on the door and the hing on the frame of the door (has a rod that goes into the frame of the truck). I worked the door several times and still the light does not illuminate when the door is open.
Front Courtesy door lights and dome lights don't work JJONES7432 Explorer, Sport Trac, Mountaineer & Aviator 6 11-10-2015 04:22 PM
Strange clock/radio wiring issue IsaacJR75 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 06-11-2015 08:45 AM
Courtesy Light 73fan 6.4L Power Stroke Diesel 0 10-09-2014 10:34 PM
F250 battery drain courtesy circuit rfaass 1987 - 1996 F150 & Larger F-Series Trucks 0 11-21-2013 12:40 AM
Courtesy light problems XNAK 1987 - 1996 F150 & Larger F-Series Trucks 5 03-28-2012 08:04 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
