weight distribution hitch reese dual cam vs equalizer - Ford Truck Enthusiasts Forums
Old 10-03-2012, 10:05 PM
amsk8er1983's Avatar
amsk8er1983 amsk8er1983 is offline
amsk8er1983 is starting off with a positive reputation.
hey guys just looking for a little input I am purchasing a new wolfpack toyhauler travel trailer 35' and can't decide on which wd hitch to get. I have heard both the dual cam reese and equalizer are good but which one is better for towing with the excursion any thoughts or experience? Also I have a 5" suspension lift and 35" tires can't decide on which drop shank I need equalizer makes a 6" max drop and also a 9" max drop should I go with the 9" just to be safe?
Old 10-03-2012, 11:01 PM
housedad's Avatar
housedad housedad is offline
housedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputation
They both will work well, but I will give a warning about the Reese. Some of their stuff is not coming through with good quality control. All the Reese stuff is now made in China. I ended up scrapping my one year old Reese Dual cam due to quality issues and tried something else. Some folks are getting good sets, some are not. To see the specific things to watch for, read and look at the diagrams on the folowing link:
RV.Net Open Roads Forum: Towing: Not happy with my Reese Dual Cam
Old 10-04-2012, 06:02 AM
Ya I was leaning more towards the equalizer anyways because I haven't heard a bad review yet on its performance. The only negative reviews have been on it being a little noisy. I just want to make sure I get the best one especially with having a suspension lift because I live in Colorado and make two or more trips to Florida a year and just want to be on the safe side. What do you think on the drop shank?
Old 10-04-2012, 09:23 AM
ExxWhy's Avatar
ExxWhy ExxWhy is online now
ExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputation
Shank Sizes
They make it easy to pick the shank. Do a couple measurements and plug it in the formula on their website.
I have an Equalizer. Easy to set up, easy to hook up and seems to do it's job well. Only complaint is it's noisy at times. Can be made pretty quiet with fresh grease in the right places.
Old 10-04-2012, 06:58 PM
rschwarzwalder rschwarzwalder is offline
rschwarzwalder is starting off with a positive reputation.
+1 on the Equalizer, works great with my Jayco 314BDS. Noise is only on sharp turns and ya get used to it. People around you don't so you get entertainment from the looks too!
Old 10-04-2012, 07:47 PM
bergy 2000 bergy 2000 is offline
bergy 2000 is gaining momentum as a positive member of FTE.
I have a Reese dual cam sway set up. I didn't realize that there were so many complaints. When I got home I double checked all my hardware. After 2 years and over 20 trips at about 150-200 miles per trip, it all looks great. I like the way it pulls and distributes the weight. No complaints from me. The bars and cams have min. wear and look like they are wearing evenenly. Reese has my vote
Old 10-04-2012, 09:09 PM
matt1751 matt1751 is offline
matt1751 is starting off with a positive reputation.
I recently purchased the Reese Strait-Line Weight Distribution System w Sway Control - Trunnion Bar # 66084 to use with a Jayco 31DSLB we got 2 months ago. So far I'm happy with it. Seems to be heavy duty compared to some others I've seen. I've had no problems with it so far.
Old 10-04-2012, 10:15 PM
Eric H's Avatar
Eric H Eric H is offline
Eric H has a good reputation on FTE.Eric H has a good reputation on FTE.
I'm happy with my Equalizer combined with v/b code springs. I tow a 30' TT.
Old 10-05-2012, 10:00 AM
grndpakent's Avatar
grndpakent grndpakent is offline
grndpakent is starting off with a positive reputation.
First you are talking about two separate issues here. The Reese Dual cam is sway control not weight distribution. The Equalizer dores have a product which does both sway and WD. I tow a 32' Airstream and have used both with satisfactory results. Presently I am using an Airsafe hitch with the Equalizer for WD and sway. This combination has given me the best ride, and safety while towing. The draw back is the greasy bars, and actual weight of the Airsafe and Equalizer. There are newer products on the market which utilize just chains to achieve the WD. I will most likely switch to one of these to avoid the weight and grease.
Old 10-05-2012, 10:04 AM
grndpakent's Avatar
The chain system is called Anderson No Sway WD Hitch, Andersen No Sway Weight Distributing Hitch field test by www.MrTruck.com - YouTube
Old 10-05-2012, 10:10 AM
Quote:
I think you're mistaken. The Reese is a weight distubeter please see this link.
Strait-Line Weight Distribution with Sway Control - Trunnion Bar - 10,000 lbs GTW, 800 lbs TW Reese Weight Distribution RP66073
Old 10-05-2012, 11:41 AM
Magilla_v6.0's Avatar
Magilla_v6.0 Magilla_v6.0 is offline
Magilla_v6.0 has a good reputation on FTE.Magilla_v6.0 has a good reputation on FTE.
I had an Equalizer brand for my Rubicon toy hauler, it worked great. You will need the 9" drop, I had the 6" on my ex with a 4" lift and shorter tires it was at the bottom of the shank.
Old 10-06-2012, 09:54 PM
Thanks for all the info guys I have decided to go with the equalizer with the 9" max drop shank. One more question though I was going to go with the 1,200/12,000 hitch but the dealership thinks I should go with the 1,400/14,000 hitch just in case I decide to upgrade my tow vehicle and trailer later on will that be overkill?
Old 10-06-2012, 10:50 PM
rlh68050's Avatar
rlh68050 rlh68050 is offline
rlh68050 is gaining momentum as a positive member of FTE.rlh68050 is gaining momentum as a positive member of FTE.
Snake oil. It may work ok for light loads being towed by vehicles that shouldn't be towing anything in the first place but that's it.
Old 10-07-2012, 12:28 AM
housedad's Avatar
Quote:
Uh-huh.. Snake oil.
It seems to pull my 34 foot 9000lb travel trailer with a 1250lb tongue weight pretty well.
Sure wish I had talked to you before I bought one. I sure could have saved myself from being happy with it.
Question about Reese Dual Cam WD hitch Jeff53 Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 2 09-03-2016 11:43 AM
5th Wheel Prep Option Tomahawk 6.7L Power Stroke Diesel 86 04-03-2016 06:02 AM
Reese dual cam sway control kconrad Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 33 12-31-2015 09:44 AM
A couple Reese Dual Cam set up questions BigGreenEx Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 6 06-04-2015 07:15 PM
WD Hitch larsonkdl Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 1 06-03-2015 09:01 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
