1950 f7 with a 417 lincoln
Help. I've got this old truck that's giving me fits. Its 1950 f7 with a. 417 flathead lincoln engine. Its a fire truck. It starts good idles ok. But when hit the throttle it will not run. It missed and sputters. Only way can get engine to speed up is to run with choke half closed.
Awesome sounding truck, love to see pictures. Be sure to check the timing on it, it can make a huge difference , mine ran too slow and needed a lot of throttle to not die when using it. The timing fixed that. If the flat head distributer is anything like a y block only a clamp that doesn't work super well holds it in place. Thankfully its a quick free check and easy fix if that's what it is. Mine was off 8 degrees lol
It bogged down pretty bad till it reved up pretty high and then always wanted to die when I tried to get going. Probably in the carb like the others said, but making sure the timing is right can make everything work much better.
1948/51 F7 and larger trucks came with the 337 flathead. FoMoCo had planned to install carryover 1948 Lincoln V12's in 1949 Lincoln's, but at the last moment, decided to use a modified 337 F7 truck engine instead.
. Hi thanks for the info. I'm leaning towards thinking the elders in my dept may be mistaken on the engine size. But they still say its a 417. Not sure it does have the distributor at the rear. But I've heard that the 337 only had a one barrel carb. This one has a 2 barrel. It was also rebuilt at least 15 or more years ago. But the guys that knew about the build are no longer with us. This old truck has been a fire truck since new and was our depts first truck ever. Its been settin for a few years and I couldn't stand watchin it just settin there not running.
Are any of the "elders" 68 years old with 40 + years of Ford parts experience? Probably not.
It's no more a 417 than the earth is flat and the moon is made of green cheese!
It's there...hidden by the air cleaner.
"Baby" Lincoln used the 1949/51 Merc body with the Cosmo's front end.
There are differences in the two 337's, because 1949/51 Lincoln's were available with the Warner 3 speed overdrive, 1950/51's with Hydra-Matic. You won't find either in a truck.
I know the truck 337 uses different cylinder heads than the 337 Lincoln.
No such thing as a 1V 337 carb. The truck 337 uses a Holley 2V carb as does the 337 Lincoln, but the Lincoln carb is not the same as the trucks.
What did the FD use before this 1950 truck, a horse drawn aperatus? Was is a steamer or a hand pumper?
. Awsome thanks again for all the help. That pic is nearly identical to the engine in the old truck. I think I'm going to go with it being the 337. Is it possible though that when the old guys did the rebuild they may have bored it out to a 417. Or do you think that's to big ?
No such thing as a 417 V8 Lincoln engine, either flathead or OHV. It's the "stock" 337 F7 truck engine that FoMoCo modified when they installed it in 1949/51 "baby" Lincoln's and Lincoln Cosmopolitans.
It sounds like you need a tune up. Check the points for cleanliness, probably rebuild the carb, maybe put in a new set of plugs. Here is information on the stock Holley 885 carburetor: Holley Concentric Tech Info - The Carburetor Doctor
I think your "oldtimer" is like so many that I've run into over the years: long on hearsay, short of facts. Probably never saw a Shop or Motor's manual. Which, coupled with a failing memory, contributes to the perpetuation of legend and myth.
Personally, I wish one COULD achieve 417" by boring one out. I'd have one of THOSE. However, in the real world, a +.060 bore job will result in 348.5. Even a .125 overbore will give you only 361". Lack of pistons limited me to +.040 which gave me a puny 344"-not quite as big as a flathead Cadillac (but better IMO).
