Help Rebuilding DANA 41 REAR AXLE
I am currently restoring my grandpas old 51 f1. I would like to keep the original rear DANA 41 rear axles as the old Flathead is going back in the truck. I have searched high and low trying to find parts to rebuild this thing to no avail. Does anyone know of any good and reliable resources to reconstruct this old axle. Really looking for new and lower gears to ehlp at highway speeds. At the moment planning on a T-5 swap to help with highway cruising.
Thanks,
Josh
Thanks,
Josh
I hate to see this described as a "drop-in" solution, there is more to it, but I do agree with your overall assessment. I put in a 9" with a 3.25 gearset and found it a little too steep for taking off with stock-size tires. I changed to a 3.50 gearset and it is just about perfect (something like 3.40 would really be ideal). The 3.50 gears will allow speeds that are at the limits of the stock brakes and suspension.
I have a zipper on my rear end! I have a 3.92 dana that I run around town and I have another dana 44 with a 2.72 ratio that i "zipper" back in when I do road trips.
I'll spend about an hour to 2 hours tops and do this swap at least once a year, sometimes more. depending on the amount of road trips. I have left the 2.72 rear in for local driving and yes its definatly a road gear but still ok for town.
I just want to say that if you want the truck to "look stock" the t5 shifter wont look stock and you have to get on your knees to see the rear swap
Gertie-The '49 F2
20
07-28-2012 05:55 PM
