IPR questions
IPR questions
I have an 03 with a hot start issue. I bought a scan gauge and can see it is not meeting the 500psi needed when hot. It has a new IPC but did not fix.The IPR is going to 75 to 85% during crank. Could the IPR be sticking or do I have a IHOP leak? What test can I do? The problem went away for 2 days then came back.
IPR questions
I am using motorcraft oil filter with factory short cover.
I did check ICP voltage but did not write it down. I will get them when I leave work this afternoon and post values. I am going to pull IPR saturday, if the screen looks funky is that a gauranteed failure?
It has been this way about a month, got there gradually. I bought the scan gauge last week and the next day it started fine hot but only for 2 days.
<HR style="BACKGROUND-COLOR: #d1d1e1; COLOR: #d1d1e1" SIZE=1><!-- / icon and title --><!-- message -->Values KOEO: IRP= 14.4 ICP= 30 IPV= .20
Values Cold: IPR= 25.0 ICP= 790 IPV= .97 to 1.05
Values Hot: IPR= 21.8 ICP=638-642 IPV=.81 TO.91
FICM main power= 48.5 solid.
Any thoughts or advice?
<!-- / message -->
<!-- controls -->
After reading ALL the thread your ICP values are bouncing around for some strange reason. Pull the IPR valve and check it. If the screen is compromised then that's the first thing I'd change.
9000_red
10-13-2015 10:30 PM
