2012 6.2L annoyance
I too have a hard time with the dipstick (oil). I'm learning how to be patient and gentle while utilizing the rotation without getting frustrated and trying to force it which it feels not right any how. I get real concerned about the little sheet metal connection to the dipstick tube breaking while pulling the dipstick out or putting back in.
Whoah, I got one now. This old pfart has a stiff back and shoulders this am after hooking up to two of the upfitter wires yesterday.
That is a real nut roll to get both paws under the dash there to splice into the wires.
I bet the designer does not have a clue how difficult he made it to reach.
Put the 7 quarts of oil in that is specified. Run the truck to circulate oil through filter and system. Let it sit for at least and hour on a level surface for oil to settle. Where the oil is on the dipstick is the normal fill level, mark on the dipstick.
When I first saw the dipstick on my dads 15' 6.2l I thought riveting a piece of plastic to the metal rod was a bad idea. If it comes loose or breaks you have to fish the plastic out of the oil pan. Don't know what is wrong with the all steel dipsticks that Ford has used for decades.
I put my 7 quarts in and that usually takes to just below the top hole... Perfect!
on
Speaking of annoyances.... My only one so far is after 10K on the clock, my supercab is starting to creak (near the top of the doors I think) when going over unlevel ground or speed bumps at slow speeds.. Anyone notice this also ? I checked the back doors to make sure they were closed. Maybe dry door rubber ??
#29
on
Ya Ford saved millions of dollars reducing the thickness of the dipstick..lol..
#30
That's good to know. I tow 7500 lbs with my '09 F150 5.4. It does the job, but every hill is foot-on-the-floor in 3rd gear. (3700 RPM). Not too bad, but I see videos of the 6.2 running nearly 6000 RPM all of the way up mountains when towing heavy. I know the motor is designed to handle it, but it still causes me stress.
