4X4 operation 101 for dummy
This 1990 F150 is the first 4wd truck I have ever owned. I do not know what is normal or not. When I put it in 4L it is geared low and the trans shifts gears...cool. When it is in 4H, it feels normal until I slow to turn in the cul de sac and then it feel like it has a flat tire or something...at this point, I took it out of 4WD. Was I turning too sharply or is something wrong...and it should turn in a cul de sac?
So what is normal and what should I do or not do with the truck? Jokes are ok, but I am a novice when it comes to 4WD and would appreciate some earnest information.
Thanks Bob
Thanks Bob
Yup as stated avoid 4wheel on hard surface even hard packed gravel can be hard on one if attempting tight maneuvers.
You can run highway speeds in 4H if you wish, won't hurt a thing.
I lock my hubs in fall (first snow fall) and leave them locked till spring, in and out of 4H "on the fly" as I wish, moving over in to a snow covered lane to pass slower traffic for example.
on
every 4x4 we have gotten was in the winter or raining season so I test them then on a backroad. the last owner of our 97 Expedition got mad at me because me and his son when cruising down a back road with it in 4x4 testing all the applications of the 4x4. So far all the trucks we have running currently have automatic hubs instead of manual.
Trav
Trav
on
4wd low is very useful,even with the hubs unlocked when traction isn't required.
it's very useful for crawling around,towing up large steep hills where you then stop at the top and shift back into 2wd or 4wd hi.a whole set of low gears to use.a lot of people don't use this set of gears because they lack the need,or don't know when to use them.that t-case alone to me,is just as a big advantage as 4wd is many times during the day.
you can drive hwy speeds in 4wd hi if you wish.
remember 4wd uses more fuel.even just keeping the hubs locked in with shift lever in 2wd uses more fuel.so if the roads are clear just unlock them,it only takes a few seconds to lock up and go again.no need to needlessly feed the greedy oil pigs.
