Adjusting tailgate on 2009 Escape - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 10-03-2012, 12:10 PM
JohnnyThunder JohnnyThunder is offline
JohnnyThunder is starting off with a positive reputation.
We live in the country and my 09 Escape has developed a slightly loose tailgate or rear door if you will and as such I am getting alot of dust coming in around the tailgate. You can see that is is not sealing about 2/3 of the way around. I cannot seem to find how to adjust the pin that the latch catches as the latch in the tailgate is non adjustable it seems.
Thanks for anyone that can help.
Old 10-03-2012, 05:25 PM
Torky2 Torky2 is offline
Torky2 has a very good reputation on FTE.Torky2 has a very good reputation on FTE.Torky2 has a very good reputation on FTE.
Ours isn't here now so I can't simply go and look at it. But many Ford Cars and trucks over the years have had door/tailgate/hatch striker bolts that were adjustable. The striker bolts have a Torx-sized recess in the end of them. Loosened with a proper-sized Torx bit on a ratchet, they could be slid around for adjustment. Inside the body panel was a captive plate with an integral nut that the striker bolt threads into.
I always wash and dry the area around a striker bolt to get it clean, and then apply some masking tape to outline the striker bolt's washer, or use a Sharpie marker to do the same, as it is easy to go astray without having the original setting for reference.
The manual says to remove the scuff plate first, and the Striker Bolt Torque is 30 Ft. Lbs.
Old 10-04-2012, 08:24 AM
Thanks for the info, I'll give it a go after work today.
'08 f250 tailgate won't latch RancherJV 1999 to 2016 Super Duty 2 09-25-2016 08:32 PM
Tailgate latch rob17 6.7L Power Stroke Diesel 6 08-27-2016 08:01 PM
Tailgate Handle Adjustment njsubi86 1999 to 2016 Super Duty 1 06-24-2015 03:57 PM
'99 SD Tailgate Latch/Lock Problem 1999er 1999 to 2016 Super Duty 5 07-24-2014 06:27 PM
Tailgate latch conchstew Explorer, Sport Trac, Mountaineer & Aviator 2 08-21-2012 02:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
