transmission failure to shift
Hey guys need some help once again. I have a 95 f 150 automatic, 5.8L. I noticed this evening as I started to drive off the truck seemed to hesitate as it moved forward. Then as I drove down the street I noticed it would not shift into a higher gear while I was going about 20 mph. It felt like it was staying in first gear. I also noticed my speedometer is not working and no odometer reading. As I drove a little further I noticed the off light on the shift lever was blinking, depressing the button on the end did not help. It would ocassionally shift, but very hard. It did seem to run a little better in the 2 setting instead of Drive. After going around the block I pulled into the drive way to see if I had any transmission leaks and check the fluid level. No noticeable transmission leaks (but it is a 95, so it leaks a little oil from here and there). Although the engine was not fully warm I placed the truck in park, ran the truck through every gear, placxed it back in park and checked the t fluid level. It was reading very high on the stick. Engine was running during this process. I'm going to let it sit over night and check it cold tomorrow and see what I get.
I just bought this truck. Dont think it was driven much as is. After the purchase I did drive it home, about 30 miles. Otherwise I've only put an additional 10-15 miles at speeds under 35 mph until this happened. Could it being over filled be causing this problem?
on
The trans in that truck is completely computer controlled and speed input is a critical input, the computer gets that input from the PSOM mounted on back of the gauge cluster and the fact your speedo doesn't function means you either have a sensor/wiring problem at the rear axle RABS/VSS sensor or the PSOM itself is bad.
The RABS module can pull-down the VSS signal before the signal continues onto the PSOM, located behind the instrument cluster. You can measure the VSS signal with a DVM at the PSOM to verify proper signal level. If it is low, try unplugging the RABS module then checking the VSS signal again. If the signal level jumps up, then you have a bad RABS module. If the signal is good up to the PSOM then you more than likely have a bad PSOM.
Sorry for using too many acronyms. Here is some info for how to use a Digital Voltmeter (DVM): Fuel Injection Technical Library » Digital Volt Meters
Fal Grunt
08-29-2006 08:36 PM
SFurtado
07-21-2005 04:02 PM
