flat bed convertion help 34" flat bed to 38" frame - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-03-2012, 12:40 AM
f350Super99 f350Super99 is offline
f350Super99 is starting off with a positive reputation.
I have a 2006 f350 crew cab drw truck that I want to install a flat bed on I know i cant be the 1st guy in t his spot looking for ideas on how to make this flat bed that was made for a 34" frame to fit my 38" frame
if any of you done this pics would be awesome!
I know they make new beds for the 38" frame but thats not in the budget ($3200) and I found a really nice used one CHEAP!
thanks
Old 10-03-2012, 09:23 PM
BrockwayMT BrockwayMT is offline
BrockwayMT is starting off with a positive reputation.
Use 2" tall crossmembers to bridge your frame to the sills on the body. You'll need the 2" of space anyway to clear the rear axle hump so it won't add any height. Don't attach the crossmembers to the flange. Weld or bolt shear plates to the crossmembers that go down over the side of the truck frame so you can bolt the shear plates through the web. The Ford body builder layout book shows you all about shear plates.
Old 10-04-2012, 07:56 PM
Quote:
I looked that up online it helps but really does not tell me the best route to adapt the 34" frame rail bed to to my 38" frame truck
Old 10-04-2012, 10:41 PM
harrisford harrisford is offline
harrisford is starting off with a positive reputation.
By using crossmembers you won't need adapt anything, the bed will sit on the crossmembers.
Convert Cab And Chasis 2015 ford F-350 to a Standard Dually Bed FullMetalJacket23 1999 to 2016 Super Duty 1 02-25-2016 03:15 AM
88' F350 CC DRW frame question abosely 1987 - 1996 F150 & Larger F-Series Trucks 3 12-03-2015 07:56 AM
Frame dimension diagrams abosely 1987 - 1996 F150 & Larger F-Series Trucks 7 11-24-2015 04:55 PM
Looking for a bed Alexbernard623 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 11-15-2015 07:03 AM
2006 F350 SRW CC chassis cab to truck bed? KDAVID1 1999 to 2016 Super Duty 4 02-28-2014 09:38 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
