1990 F150 5.0 4X4 starts then dies - Ford Truck Enthusiasts Forums
Old 10-02-2012, 11:09 PM
1FlatbedAmbulance's Avatar
1FlatbedAmbulance 1FlatbedAmbulance is offline
1FlatbedAmbulance is starting off with a positive reputation.
Just bought this truck and I inherited this problem. It will turn over, it will start (sorta) and then dies. If you pump the pedal, you can keep it running, but very badly. I have verified fuel and pressure to the rail and I have spark. New TPS, fuel filter, fuel pressure regulator, dist cap and rotor. If I turn the key and let the fuel pump prime a few times it acts like it wants to run but after a few revs of running it dies.
Any help would be very appreciated...as I am not having fun.
Bob
Old 10-02-2012, 11:16 PM
norfolknova norfolknova is offline
norfolknova is gaining momentum as a positive member of FTE.
First thing you need to do is pull the engine trouble codes and post them. Knid of sounds like it may be the idle air control valve is part of the problem, but if you pull the codes it will help greatly in determining the problem
Matt
Old 10-02-2012, 11:29 PM
Matt, the codes were 22 63 & 47. At the time, I had the TPS off of the truck and I assume that was the reason for the 63 code. I installed a new one with no results on the issue. Will the MAP sensor cause those symptons?
Old 10-02-2012, 11:42 PM
Yes I beleive it will, you also have an O2 sensor codeaccording to the chart I looked at, so the computer is thoroughly confused by the bad readings of the MAP and O2
matt
Old 10-02-2012, 11:46 PM
Well, I'm going to cross my greasy fingers and throw a MAP sensor and 02 sensor at it and hope it will run tomorrow. I appreciate the fast reply Matt and I'll post the results.
Bob
Old 10-02-2012, 11:52 PM
Pull the codes again before you buy the parts and make sure they are consistant since you changes the TPS. O2 sensors are relatively cheap and it can't hurt to put a known good one on, same with the MAp
Matt
Old 10-02-2012, 11:54 PM
Will do and thanks again.
Bob
Old 10-03-2012, 07:05 PM
That was it. The MAP sensor was bad. I also installed an 02 sensor and my codes are clear. Matt, thank you very much for the help and direction.
Bob
88 f250 randomly dying/not starting bk1200r 1987 - 1996 F150 & Larger F-Series Trucks 1 08-17-2016 10:31 PM
Random no fuel pressure at start up. 9rudy9 1999 to 2016 Super Duty 7 02-01-2016 11:46 AM
Starts an then dies when cold. 4drf350 1994.5 - 1997 7.3L Power Stroke Diesel 3 04-01-2015 01:32 PM
05 wont stay running? 428fourby 2004 - 2008 F150 1 12-20-2011 10:23 AM
97 Explorer 4.0l ohv runs then dies steadtech Explorer, Sport Trac, Mountaineer & Aviator 2 03-19-2010 08:07 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
