V code Mod
WE3ZS did it with a set of x-code springs so I don't see why you shouldn't be able to do it with the v-codes.
Here is a link with pics that show how he did it.
https://www.ford-trucks.com/forums/1...-question.html
Tim M
Tim M
Tim M
Tim M
I gained nearly 2" when I installed V-code springs on my otherwise stock X. If it weren't for the airbags I'd be higher in the front than the rear, so I'm not sure that you'd need the increased height.
If you want to stay closer to even height then you should install the RAS with the B-codes un-modified.
Most mod the B-codes so they can gain a few inches in the rear. It is also supposed to help with the ride but the RAS should handle the difference in the ride that is gained with the moded B-codes.
Tim M
Tim M
Ah well, then disregard my previous post.
Don't mod the B's, keep them original and along with your stock blocks and the RAS, you *should* be spot on, or fairly close, to an aesthetically pleasing rake/stance.
Stewart
Stewart
Thanks guys, I didn't want to do the front end twice!! I am leaning toward foregoing the added leaf in the front and sticking with stock B 's.
