Idling issues
Idling issues
Hi guys,
2000, F250, 4x4, Crew cab, 37" tires, no cat, 4.88 ratio, 5 star tunes, 200K miles
2 weeks ago the fuel pump got issues on my way back from a capig trip. lucky for me he truck limped to a town were i could find a replacement generic pump and fuel filter.
after a week the truck start stalling at idinlg after a 20 - 30 min drive. I was planing to replace the generic pump, just not that soon. Any way i got a new Bosch complete pump and swap it and put a new fuel filter
160 miles later the rpm's go crazy when idling. they start falling and the rising until the engine stalls. its the same behavior under 2000 rpm. as soon as the engine goes over 2000rpm it works fine.
any ideas? i'm thinking pressure regulator
Ivan E
Ivan E
Before throwing parts at it, clean your MAF sensor with MAF cleaner. Gray can made by CNC. And remove the throttle body and clean it good. Take out the IAC and spay it down good but don't push it in! Let dry, reinstall with new gasket, and see how it does. keep battery unhooked while you do this.
It really sounds like the IAC - before putting too much effort into swapping parts or anything else, when it acts up, try putting your foot on the gas just a little bit - like 1/4" and see if the idle smooths out and stays where it should. Once the IAC sticks, it seems the PCM goes nuts trying to control the idle and usually doesn't
makemeknowit
Modular V10 (6.8l)
18
11-04-2014 03:15 PM
kjspylite
05-17-2007 11:42 PM
bcsbadboys
08-14-2002 04:40 PM
