Where is all my effing brake fluid going???
Well, no worries on the MC or the booster.
Before disconnecting the brake lines from the MC, I disconnected it from the booster just to have a look... no evidence what-so-ever of it leaking into the booster.
So after bolting it back in place, I got under the truck, and almost immediately saw that the backing plate and rim on the passenger side rear tire were wet with oil. Pulled off the drum and sure enough the whole brake system was coated with oil from a leaking wheel cylinder.
Since I didn't have the replacement cylinder I just sprayed it down with some brake cleaner. I will just have to replace it in a couple of weeks when I have the time again.
Thanks again guys.
Thanks again guys.
Caleb H
48
02-09-2009 05:02 PM
Charlie01
05-26-2004 07:09 PM
