Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Ford V6 > 3.8 & 4.2L V6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 10-02-2012, 07:02 AM
herfarm herfarm is offline
Garage is empty, add now
herfarm is starting off with a positive reputation.
Help! What part is this? 2001 F-150
Click the image to open in full size.Water is seeping thru the metal block that the bolt is in. We can find the bolt part but not the block part. Pic https://twitter.com/i/#!/Herfarm/med...com%2F3LdSbyMf Click the image to open in full size.
  #2 (permalink)
Old 11-28-2012, 09:33 PM
ford_devel_dog ford_devel_dog is offline
ford_devel_dog is starting off with a positive reputation.
for starters what engine and got as better pic, use paint to circle it, i got alldata so i can define most anything
  #3 (permalink)
Old 12-07-2012, 12:23 AM
mitch1204 mitch1204 is offline
mitch1204 is starting off with a positive reputation.
I believe you are talking about that brass looking bolt. Actually it's a plug and it screws into the lower intake manifold.
1997 thru 2003 used the same lower intake manifold. But on the 1997 to 2000 I believe that hole is used for the coolant temp sensor. On the 2001-03 they plugged that hole and used what they call a head temp sensor that screws into the back side of the drivers side head.
Usually you use pipe dope or teflon tape on that bolt and is probably your problem. I never seen one crack?? If it did you might get lucky with JBWeld or something similar as there is coolant flowing through there under 16 psi pressure. I just happen to have a 2001 lower intake from an engine swap job I done.
That chrome pipe with what looks like you got epoxy on it is your fuel rail. It connects the fuel line to your injectors which also slides down and bolts into the lower intake.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
